Rover Engine in an '62 F-85 Cutlass
#42
I was not aware that the Rover block lacked the provision. I have a 1990s vintage T5 with the factory hydraulic throwout bearing for mine, as the clutch linkage takes up precious space for the driver side exhaust.
#43
The z-bar pivot ball mounts to the block, not the bellhousing.
I have dual exhaust system on mine and it would have been even more of a nightmare if the Z Bar was still there.
I am using the factory, original, T-10 4 Speed tranny (for the guy that asked)
#44
Car is almost ready for final primer.. Seem I can not upload pics... they up load but do not get attached to the post.. any ideas?
#47
This is the one I used.. Only had to use a silicone elbow at the lower outlet
https://shop.championcooling.com/Per...mpest-SKU-6163
#50
Looks amazing! If it helps anyone, then the front covers and sumps can be fitted to late model 4.0/4.6 Rover V8 distributor-less engines, as can some Buick V6's as they were derived from the V8's. The V6 also has a helpful side mounting oil filter mount that can help with clearance issues.
