73 omega heads?
73 omega #8 heads, compatible 4 barrel intake?
Im looking to invest in a 4 barrel intake manifold, currently the omega has #8 heads, do i need to replace the heads or is there a manifold that will accomodate the heads? Ive tried looking up as much as i can, i know the #8s are smog heads, i plan on either replacing the heads or deleting the egr. Just curious if a manifold out there fits or if i need to replace the heads. I have a deal lined up for a 600 cfm edelbrock carb, not my initial desire for an install but just about anything is better than the 2g currently in it
The Edelbrock 3711 intake manifold will accommodate the egr. Also there is a member here selling a rebuilt quadrajet 7043250, which is correct for a 1973 350 for a good price.
https://classicoldsmobile.com/forums...-choke-180617/
If you'd like a bump in compression install a set of 5,6,or 7 heads with your 73 pistons. Alot less dished than 71 and 72's. Would really make a difference in how it runs. That and a cam bump would really wake it up.
