Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
66 starfire suspension question
Old May 13, 2016 | 12:50 PM
warrob's Avatar
I am looking for 2" front dropped spindles and improved coil springs for the front and 2" dropped rear springs.
Do you know other B-bodies that offer 2" dropped spindles that would fit my 1966 starfire? I am trying to set up a protouring stance and ride within budget.
Rob
PS. I was told that a 66" impala could work but I am still not 100 %convinced.
Old May 13, 2016 | 08:24 PM
Charlie Jones's Avatar
Phantom Phixer
I am 100 % convinced that 66 Impala spindles will NOT work.
"A" bodies shared a lot of suspension parts between makes . " B" bodies did not , at least not until 1971.
Old May 14, 2016 | 06:12 AM
warrob's Avatar
Thanks for the tip.
Old May 14, 2016 | 06:48 AM
I'd be surprised if anyone makes dropped spindles for these cars. The 1965-1970 Olds and Buick B/C body cars use different spindles and suspension from the same vintage Chevy and Pontiac B-body cars and the spindles will NOT work. The Impalas used the smaller wheel bearings from the A-body cars, along with the 5 x 4.75" wheel bolt pattern. The Olds full size cars used larger wheel bearings (which is why the Chevy spindles don't work) and the 5 x 5" bolt pattern. Yes, the 65-66 Jetstar 88 is the exception, as it does use the same spindles and bolt pattern as the Chevy.
Old May 14, 2016 | 07:05 AM
warrob's Avatar
Thanks for responding Joe, this has been an uphill battle in getting just the right stance that I am looking for. No wonder why none of the hotrod shops call me back. But, in this case I am just not ready to give in and will have to explore this some more. Thanks again and any advice in finding these spindles or having some made would be great.
Old Feb 19, 2017 | 06:09 PM
65Fire's Avatar
Do you happen to know if the suspension connections to the frame are the same on all B Bodies? Would the upper and lower control arms from a Chevy fit in the Starfire frame connection points?
They had the same steering, right? Something has to be common here!
Old Feb 19, 2017 | 07:13 PM
Go back and read Post #4. NOTHING interchanges. Frames are different, suspension is different, attach points are different, steering linkage is different. Ball joints are different, spindles are different. Chevy uses strut rods on the front like a Mustang. Olds does not. Chevy uses a three link rear suspension with a panhard rod. Olds used a traditional four link.
mr bojangles
Suspension & Handling
Feb 10, 2021 06:03 AM
bsherman211
May 12, 2017 09:09 AM
scareyslo
Dec 26, 2015 07:51 AM
sleroy
Oct 8, 2012 07:21 AM
JSGD1966
Dec 5, 2007 01:23 PM
