Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
64 Starfire speedo
Old January 16th, 2018, 10:19 AM
OLDSter Ralph's Avatar
64 Starfire speedo
I was looking at a pic I took of the speedometer. I am guessing the speedometer has been "spun back". I doubt the car has only 25957 miles. Notice how the "2" lines up lower than 5957.
OLDSter Ralph is offline
Old January 16th, 2018, 10:20 AM
Old January 16th, 2018, 10:51 AM
I can't comment on the actual miles on the car, but it is not uncommon for the numerals on the odo drum to get misaligned over time, especially if the drum gets sticky between the wheels. I had to change the odo drum in my 62 because of this. "Spinning back" isn't normally done. It's much easier to simply pull the speedo, remove the odo drum, and set it to whatever you want.
joe_padavano is offline
Old January 16th, 2018, 12:38 PM
Thanks Joe.
Could they be cleaned or lubricated without ruining them ? I am thinking WD40, LPS1 or "3 in 1 oil".
I might as well set to "0" when the car goes back together. I don't think mileage certification is a factor on a car this old.
Old January 16th, 2018, 01:30 PM
I had another speedo, so I just swapped mine. The drums are plastic and most cleaning solvents will damage the lettering. Electrical contact cleaner may be your best bet. Do not use a lubricant like WD40 or anything petroleum based on the plastic. Silicone spray is a better choice.
smaye
November 25th, 2013 06:59 PM
tpawlik
September 9th, 2011 09:05 AM
Redog
June 12th, 2007 11:29 AM
macvic
March 10th, 2007 08:31 PM
VegasDelta
October 12th, 2006 04:48 PM
Quick Reply: 64 Starfire speedo
