Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
62 Starfire Disappearing Brake Fluid
Old Oct 25, 2010 | 04:47 AM
tpawlik's Avatar
The master cylinder, booster, lines and wheel cylinders are all new and I have a check valve in the vacuum line to the booster. I had to bleed the brakes several times to get all air out. I also bench bled the master cylinder before I installed it. I drove the car home 8 miles from the upholstery shop with good pedal and brakes on Saturday. Yesterday I pulled it out of the garage. No brakes. Master cylinder is empty. I now thnk thats why I had to bleed the brakes so many times. The fluid is going somewhere and when I step on the pedal I put more air in the system. The wheel cylinders are not leaking.
Bad master cylinder? If so am I filling the booster with
Old Oct 25, 2010 | 04:50 AM
bil's Avatar
bil
I had that happen one time-the fliud was going into the booster.The rear seal in the Master was defective. ---bil
Old Oct 25, 2010 | 05:56 AM
tpawlik's Avatar
Sounds like I need to remove the booster and drain it. I hope the brake fluid does not damage the air seal in the booster.
Thanks.
Old Oct 25, 2010 | 05:58 AM
olds425's Avatar
If that is happening , the booster is bad. And unfortunately new parts fail, especially now a days.
Old Oct 25, 2010 | 08:34 AM
chequenman's Avatar
Arrow
The Booster shouldn't be bad if it's only been a very short while, it's the rear seal in the Master Cyl. that's probably the culprit....
Old Oct 25, 2010 | 08:46 AM
citcapp's Avatar
X2 on this, Common problem with cars that set a lot. You can rebuild the master cylinder with a kit and a cylinder hone, very simple task.
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
ztim
22
Jun 29, 2008 05:13 AM
jeffrey
Mar 6, 2008 06:43 PM
dynamic88
Jul 28, 2007 08:04 PM
