Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
62 Starfire
Old Apr 9, 2011 | 02:52 PM
tpawlik's Avatar
62 Starfire
Does the tachometer wire attach to the + or - side of the coil?
Thanks.
Old Apr 10, 2011 | 09:23 AM
The tach connects to the same side of the coil as the distributor. This SHOULD be the negative side, assuming the coil is connected properly, but it is possible for someone to connect the coil backwards and the car will still run.
Old Apr 11, 2011 | 04:08 PM
tpawlik's Avatar
Thanks Joe,
I thought that was right. Guess that means something is wrong with my tach. I harvested this tach from a donor console that was in better shape than mine. I was not able to test it before I installed it. Something I can live without.
Want to take a crack at my wiper motor problem listed in the electrical section?
Old May 10, 2011 | 12:36 PM
trackz man's Avatar
Originally Posted by tpawlik
Thanks Joe,
My tach had the same problem. It does go to negative side. I have since sent it out to WV along with the clock for repairs. Will let you know the outcome...
1962oldsguy
May 19, 2019 08:08 PM
Kyle's 77 Cutlass
Jan 1, 2014 09:06 AM
Oldssupreme
Feb 3, 2013 06:26 AM
Oldssupreme
Feb 3, 2013 06:24 AM
slhandpaz
Oct 24, 2005 05:17 PM
