Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
61 Starfire (body / frame hight)
Old Dec 2, 2006 | 03:24 PM
bjtstarfire's Avatar
61 Starfire (body / frame height)
Question About the way my car sits from side to side across the back and front.
First the suspension was overhauled by me with all new components and they everything is seated correctly and the car had this slight issue prior to the overhaul.
From the front of the car it looks level from side to side even though the measurements are only out about one half of an inch off. The measurements were taken on a flat surface to the top of the front wheel lips. I am not too bugged by this.
From the back the car looks un-level from side to side (not to bad, no one can really key in on it – but I can). The measurements are out about one and one half of an inch off. The measurements were taken on a flat surface to the top of the rear wheel lips and to the frame rail aft of the rear tires. If I measure off the axel they are right on the money and level.
Should I worry about this? Should I take it to a frame shop or will this create more problems?
Does any one have the correct ride height dimensions that they can give me and the reference points?
Ben
Old Dec 26, 2006 | 03:57 AM
That is good news and I am going to see if that is the case here.
I'll keep you posted on my findings in the next few weeks.
Old Dec 26, 2006 | 08:13 AM
Oldsguy's Avatar
Past Administrator
Frame height and body height could be different if a body mount pad is worn, crumbled or missing. check that too.
Old Dec 26, 2006 | 04:23 PM
Paul,
I see the section in the repair manual - obvious but I missed it the firs time around.
Dan,
Thanks I did look the mounts over and they are fine along with good solid metal that they butt up to.
Thanks once more to all of you. I think the problem has to be the springs - all other areas have been ruled out.
Ben
Old Jan 7, 2007 | 07:55 AM
NO Luck!
We had 65 degree weather this weekend in PA so my dad and I worked on the rear springs. I wish the problem was corrected but it was not. Here is what we did:
1> I took the spring on the lowest side of the car and rotated it to what I thought might have been a better position. No success same basic condition in ride height.
2> I took the spring on the lowest side of the car and then flipped it. No luck same condition in ride height.
3> I took the springs out on each side of the car marked them and looked them over on the garage floor. To me they look the same in every way possible.
4> I then reinstalled the springs making sure that they were swapped from one side to the other and seated well. The car still has the same ride height problem – close 1 ½” to 2” difference from one side to the other on the same side that always had the lowest measurement. The problem stayed in the same spot and did not travel to the other side.
I looked at the instructions from the springs and only the front springs had a white paint mark for installing them in the up position the rears seemed not to matter, according to the documentation. With that said I still flipped them again and to no avail I still have the same uneven ride height. Help – what do I do now? I am not looking to have it perfect but you can see with the eye that it’s uneven.
Any suggestions and help would be welcomed.
I have been in contact with EATON Detroit SPRING CO. and I seem to get the statement that the problem is not the springs. They may be right but what can I troubleshoot next.
Below is part of an e-mail I sent EATON SPRING after they told me the rear is not level and the springs are fine:
This is what I did to check the rear and what I seen completed at the frame shop.
I measured the rear from two reference points near the shock absorber mounting locations on the axel, to a level garage floor and they were level (out just about 3/16”).
The frame shop did the same thing but they measured to the lift system not the garage floor. They also suspended a level from wire lengths hanging off the rear axel and the results were equal.
If you can advise me on another technique please be as specific as possible so I can ensure that I do it correctly.
When I measure the sprung weight of the car, the measurements differ as you know from my earlier e-mails. This is crazy the only thing I can think of is that I need to add a big shim on the bottom spring mount of the lowest side (which I do not think is safe), try a new set of springs (incase they are different some how), or get one spring that is bigger that the one I have now to address the problem. The original car springs were shot – the car sat real low but it was even, go figure.
Oh! one added thing the frame shop stated. The front is uneven by about a ¼” – you can not tell by the naked eye. They said that as the back low side was corrected that the front will become more even.
PS. Tires have same psi levels and the frame shop ruled out any problems with the car. Measurements from ground up to axel are perfect. Same measurements from ground to frame rails are about 1 ½” to 2” out…
Old Jan 7, 2007 | 12:17 PM
Sorry for the confusion its just more difficult to describe all this in text. The issue before the suspension overhaul was very small and from the eyes perspective the car sat level but very low.
About the "carrying height", as you and the manual state for the rear measurement "rear spring height and for all except S.W.' it should = 5 13/16" to 6 9/16". Well I did this measurment and the readings were in the 7" low side and 8"+ high side range. I can live with the extra height but the unevenness is as you know is what bugs me.
Front measurements with the welding rod were 12 1/2" and 12 3/8".
I will try what you suggested and look at the front more closely and post back here. Thanks for the headsup.
I had no spacers in the front or rear and as for the original springs - bad luck but the rears got tossed and the fronts - well they are collecting dust in the garage.
Old Jan 27, 2007 | 03:30 AM
I guess I may never really find out what was causing the lean. I tried every thing that was offered by many people. So Eaton Spring stretched my spring for free and the car is now looking good.
sixty9olds
Jun 14, 2011 06:43 PM
jo75olds
Apr 25, 2011 07:51 AM
1969goatman
Aug 30, 2010 07:44 PM
DJMatthews
Dec 5, 2006 01:28 PM
