1963 F-85 trans. from 79 Camaro
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
Hello Everybody
Last year we found out there is a wrong trans in our car. A TH180 from OPEL
. That got a lot of problems to the Olds. The drive shaft is as wrong as the exhaust system. Result of the different length to the original TH 240.![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
Because we want to change to a stronger trans, drive shaft and an original exhaust system. So we kept on searching ebay for a year.
TOMORROW there ends an auction in Germany for a TH 350 from a 79 CAMARO.![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
Does anybody knows for shure if this trans got the same length and bolt pattern as the TH 240 ???![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Thank`s for your efforts, Claudia & Martin![Smile](https://classicoldsmobile.com/forums/images/smilies/smile.gif)
![EEK!](https://classicoldsmobile.com/forums/images/smilies/eek.gif)
Last edited by convertible 63; January 22nd, 2011 at 08:41 AM. Reason: wrong words
Thank you Gene
Well, the point is, Rover Transmissions are expensive and I don`t know what Rover code tells me if an interchange is possible
The Camaro piece costs about 230 $ by buy it now and petrol to pick it up
Regards from Black Forest, Claudia & Martin
![Mad](https://classicoldsmobile.com/forums/images/smilies/mad.gif)
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
![Cool](https://classicoldsmobile.com/forums/images/smilies/cool.gif)
If your 63 still has the original aluminum 215 V8, it has a unique bolt pattern. The only automatic transmissions that bolt up are the original Rotohydramatic 2, the Buick Dynaflow used in the 61-63 Skylarks, and the Rover trans. I don't know what you have in there now, but there's no Opel trans that bolts to the 215.
Location: I live in a small community in north of Sweden, (more details to come)
![Red face](https://classicoldsmobile.com/forums/images/icons/icon11.gif)
Hello Everybody
Hello Everybody
You can use the 350TH, but you need a "spacer" between the engine and the trans.
Joe, you`re right. Our trans is a Rover one, a TH 180. The only available Rover model that fits. Claudia told me.
She knows more about our cars than I will ever do. ![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
Dr. Olds, thank`s for that information.
But what happens to the length of the drivetrain between engine and diff. by using a "spacer" ? We like to get rid of the one piece drive shaft to mount a split drive shaft that belongs to the Olds. Otherwise the original exhaust system wan`t fit.
I found those spacers a few month ago in the net but lost them
Will start search right now again and tell you what I got.
See you, Martin
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
See you, Martin
![Post](https://classicoldsmobile.com/forums/images/icons/icon1.gif)
See you, Martin
See you, Martin
You might have to cut the drivetrain(driveshaft?) and weld it after adjusted the length. I don't understand the problem with the exhaust, help me there if you can. But why not try to find an original gearbox? I have an -63 Cutlass Coupé with "Slim-jim" trans, not the best but it works.
Leffe // alias Dr.Olds
trackz man
August 29th, 2016 04:32 PM
Winnipeg Cutlass
April 17th, 2006 03:15 PM
