Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
1961 Starfire Holiday Hardtop
Old May 6, 2020 | 08:05 AM
  #161
61Bat's Avatar
Originally Posted by cherokeepeople
love the old school offy valve covers.
I know, they are beautiful. 😊
Installing them meant losing the road draft tube and neccetated installing the PCV, losing the rear PS bracket and I moved the 67 Cadillac PS cooler to the drivers fenderwell.
Old May 6, 2020 | 08:09 AM
  #162
Charlie Jones's Avatar
Phantom Phixer
Originally Posted by 61Bat
Next item on the agenda will be installing a dual pot master cylinder.
A 1966 Cadillac M/C should work nicely with the stock power booster .
Old May 6, 2020 | 10:01 AM
  #163
Don R.'s Avatar
John, that car looks better every time I see it.
Old Nov 15, 2020 | 01:26 PM
  #164
61Bat's Avatar
Heres a tease on the rear Starfire Holiday Hardtop custom rear panels. Convertibles had one full and 1/2 "U" shaped trim piece on the rear panel for comparison.
Using the same 1/8" pvc foamboard as the front panels and unfortunately sacrificing the upper section of the factory Dynamic 88 rear panels. Also new window fuzzies. I ordered extra embossed metal from SMS to match the front panels.
Old Dec 13, 2020 | 02:47 PM
  #165
61Bat's Avatar
Old Dec 24, 2020 | 01:38 PM
  #166
61Bat's Avatar
Still a few wrinkles to iron out and install new window fuzzies....but you get the idea. Excited to see what they look like in the car.
Old Jan 2, 2021 | 05:38 AM
  #167
61Bat's Avatar
Interior complete
Here you can see the wider filler panel between the seat and the side panel. Also you can see the gap between the narrower convertible seats and arm rest. Perfect storage for your Glock.
I may be biased but........i love it.
Old Jan 2, 2021 | 09:36 AM
  #168
Phantom Phixer
I love it too .
Now all you need is a set of Jaswest panels and side trim .
And you will have a " one of none " '61 Starfire coupe .
Old Feb 10, 2022 | 04:20 PM
  #169
61Bat's Avatar
Well I gave it a chance. I'm going to start accumulating parts this year and the 61 is going under the knife. Plans are a full front frame stub to faciitate modern suspension, steering and brakes. And then a heart transplant. Details to follow.
Old Feb 23, 2022 | 07:13 AM
  #170
edzolz's Avatar
By chance, were you in the Dallas TX area two weeks ago? I saw a black 61 Bubble top near Baylor hospital looked very much like your car.
Old Mar 22, 2022 | 01:20 PM
  #171
61Bat's Avatar
Nope, not me edzolz.
Old Mar 22, 2022 | 01:23 PM
  #172
61Bat's Avatar
https://www.scottshotrods.com/spring...placement-ifs/
This is the front IFS system I am going with. I've talked with Justin the owner and I'm really impressed with his products. I plan on attending the open house he is having in May, looks like a good time! I guess I'm most impressed in that it is not Mustang II stuff. I'm going for the power rack and pinion and then thinking of starting off with the 12" disc brakes so I can keep my 15" wheels for now and upgrade later.
Any thoughts?
Old Mar 23, 2022 | 10:06 AM
  #173
Don R.'s Avatar
Any thoughts?
Wow, that is a big step. Is this system specifically designed to fit into your frame or do you have to figure that out yourself? Will the coilover shocks support the car weight sufficiently to provide a decent ride? What are your plans for the rear suspension?
Old Mar 23, 2022 | 01:23 PM
  #174
61Bat's Avatar
Talking
Scotts has built complete frames for 61 Oldsmobile but what I'm going with is his spring pocket frame replacement; so Scotts has all the frame dimensions rendered in CAD to make my frame section. Modifying the frame in this manner lets me keep all the factory body and core support mounts. Alden offers different spring rates for the weight of the car. Rear suspension will stay stock for now but eventually I see myself replacing the 9.3 with perhaps a Dana 60 with disc brakes. This is only the beginning.
This is not a 61 Olds but you get the idea
Old Mar 26, 2022 | 10:03 AM
  #175
Don R.'s Avatar
Cool, keep us posted - these pics will not enlarge, can you repost?
Old Mar 30, 2022 | 08:18 AM
  #176
61Bat's Avatar
Those images and more here^^
Also looks like i'm going to do 18x8 and 18x9 Detroit Steel Wheels D-towns w my stock poverty caps and then run 13 inch Wilwood discs on the front. I'll need some big brakes to slow down the 540. oops........
Old Sep 24, 2022 | 10:23 AM
  #177
61Bat's Avatar
18s are on. I went w 18x8 all around for now but probably going w either 18x9 or 20x9 on the rear when the new motor goes in. All the front suspension from Scotts Hot Rods showed up last week and my friend Mark at Bielman fabrication says he'll be ready for the car in January. More to come.....
Old Jan 4, 2023 | 05:26 AM
  #178
MichiDan's Avatar
Nice. Been a while since I checked this site but this is still my favorite build. I love a 61 in any configuration.
Old Feb 12, 2023 | 10:44 AM
  #179
61Bat's Avatar
Ready to yank the 394 and slim jim.
Old Feb 12, 2023 | 10:47 AM
  #180
61Bat's Avatar
Old Feb 14, 2023 | 11:22 AM
  #181
Don R.'s Avatar
Looking forward to the build!
Old Mar 19, 2023 | 04:36 PM
  #182
61Bat's Avatar
Old Mar 19, 2023 | 07:07 PM
  #183
Phantom Phixer
Here's a guy looking for a running 394:
394 - ClassicOldsmobile.com
Old Mar 21, 2023 | 01:19 PM
  #184
61Bat's Avatar
Thank you Charlie, but I sold my 394 the day after I pulled it. It went to a guy putting it in a red 64 Dynamic 88 2 dr ht. He sent me a video of it already running in the car.
The Offenhauser valve covers went to someone else. Almost paid for the new wheels. I ended up putting the Detroit Steel Wheels on my 83 GMC shorty.
Also, if not obvious, I'm going to do all the crossmember surgery myself.
Old Mar 24, 2024 | 12:42 PM
  #185
61Bat's Avatar
So its hard to believe its been a year since my last update. The front clip is finally complete. I ended up doing it all myself.
Firewall and floor modifications were necessary. I hated cutting my rust free floors. The floors are 80% complete....my Gear Vendors OD arrives Tuesday and i need to check clearance before i finalize the floors.
Once the floor is complete, then its really plumbing and wiring.
Good shot of the Wilwood 13 inch rotors and 6 piston calipers. My first safety wire job!
So.....here we are a year and 3 days later. Much progress has been made. The front end is complete. I need to source some longer bolts for the R&P because I needed to space it out 1/2" and i'm getting the sway bar powdercoated red. but all the welding and painting is done. I've reassembled it for (hopefully) the last time. Everything is greased and torqued.
John
Old Mar 26, 2024 | 12:04 PM
  #186
Don R.'s Avatar
Wow, that is impressive DIY!
Old Apr 4, 2024 | 03:50 PM
  #187
therobski's Avatar
Wow, such FAB work. If I was closer to St. Louis I come and bug you- and learn some fabrication skills! And turn some wrenches with you. Over and out.
Old Mar 3, 2026 | 11:33 AM
  #188
61Bat's Avatar
Still a work in progress. The long awaited engine is finally here. Im currently assembling the 9.3 with all Fabcraft guts and Willwood brakes. Maybe this is the year.......
a little bigger than a 394......
Old Mar 5, 2026 | 10:18 AM
  #189
Don R.'s Avatar
Keep up the good work.
Old Mar 7, 2026 | 09:18 AM
  #190
61Bat's Avatar
Thanks to Fabcraft for making this easy.
mjmyaire
Aug 12, 2020 06:56 AM
darksidemxer
Nov 11, 2015 07:09 AM
Skylinerwjmc
May 21, 2015 03:41 AM
Tom442
May 31, 2012 03:55 PM
rlafash
Sep 24, 2010 09:39 AM
