Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
1961 Oldsmobile Starfire Convertible Cowl Tag Decoder????
Old Mar 21, 2011 | 11:39 AM
YONO's Avatar
Does anyone know of a website to decode the cowl tag for a 1961 Starfire Convertible. I have attached a photos of mine but can't find where the complete decoding for the ACC, TRIM etc... I also have the engine number as well if someone could help me I would really Appreciate the help!!!
Teri
In case you can't see the photos here's the numbers off the tag
OLDSMOBILE DIV. GENERAL MOTORS
03B LANSING MI
STYLE 61-3667 BODY LA 1652
TRIM 934 PAINT N
ACC. 493
Old Mar 21, 2011 | 01:40 PM
jaunty75's Avatar
Don't worry, there's a number of people on here who can decipher these things. Someone will respond soon I'm sure.
One thing I do know is that the "03B" refers to the 2nd week ("B") of March ("03") as the build date for the car. So it was built in March 1961.
Old Mar 24, 2011 | 08:22 AM
YONO's Avatar
Jaunty75-----thanks for the response. looking forward to some help on this one!
Old Mar 24, 2011 | 10:27 AM
hurst68olds's Avatar
Here's a little bit more .....
03B - assembled in March / second week
61 - 1961
3667 - Starfire 2dr convertible
LA - Lansing, MI assembly plant
1652 - 1,652nd convertible body
934 - trim
N - Cordovan Mist Metallic
493 - accessory
Old Mar 24, 2011 | 11:19 AM
YONO's Avatar
Hurst68olds ---Thanks for the information. Do you happen to know if the Accessory code of 493 is for the headlight dimmer option? I have gone through this car and it seems that that is the only thing I can think of that was not standard on the 1961 Starfire's was the headlight dimmer and this one has it....any ideas? Thanks
Old Dec 14, 2016 | 02:56 PM
mjmyaire's Avatar
From the information I have 493 is the code for both options D1 and D3 which are electric antenna and bi-phonic speaker system. This is from the '62 codes which I assume are the same for '61. I have not seen a similar list for '61.
ratrocket
Nov 22, 2019 01:56 AM
chrisneu68olds
May 10, 2017 09:46 PM
Joshua Mollet
Dec 13, 2012 05:34 PM
gtdrvr
Jan 1, 2012 08:08 AM
bjtstarfire
Paint
Feb 26, 2009 06:14 PM
