Washer pump not working
Same Situation ('68 442)
I have the same trouble - all looks OK, even rebuilt the pump part. No good. All lines are clear and I have current at the pump connectors when pushing the dash button.
Same question - "What gives?"
I'm going to pick up a new [valve body?] tomorrow, (that square thing that the hoses hook to). If I play with the little rubber stoppers I can get air through it but a second later it stops.
I'll let you know if it works. Advance has the valve body and entirely new pumps if that helps.
So you're saying that the solenoid pulls the arm onto the plastic ratcheting gear, and that the pump goes through several cycles of operation, then releases, but that even though the piston is moving, no water comes out, right, Mac?
If so, then, yes, a rebuild kit ought to fix it right up.
This is a common failure mode for these. The rubber valves and piston seal dry up and stop sealing.
The good news is that a kit containing all the parts is easily available, easy to install, and costs about five bucks, if I recall (it was a few years ago, anyway).
Just did my 64 dynamic 88. Kit worked fine. But check to see if the nozzles are clear, mine were caked with gunk. And make sure the lines are actually clear. I blew air into mine and both had an obstruction.
The kit I bought for my 67 442 only came with the new plastic 3way cap and gasket. My actual bellow had a small tear in it. I do not remember the name of the company that carried the bellow. It was a Corvette company.
I think my bellow is good to go. If not, Advance has the entire pump mechanism for about $20
After driving to town I figured I MAW get the entire pump for $20 rather than the valve body for $7-ish. It would take me $6-$7 in gas to get there and back if I had to go back. The pump works great and is A LOT quieter than my old one. And the cover seems to work fine. The only thing that surprised me was that the washer stream didn't even hit the windshield.....but the rear window and truck got nice and clean
A little bending and I'm good to go.
A little bending and I'm good to go.[/QUOTE]
That could be a nice option to have at the drive-in. Geeez my wife could be laying on the trunk getting ready for the movie to start, Jus a little squirt and she's already wet before the movie starts. Put-'r' ther !!!
I need a specialized tool to get it off?
PM me your address in case I can get it off. Or like I said, I'll send you the whole pump if you'll pay for shipping.
I completely understand. I learned what they were when trying to remove the secondary metering plate from a Holley 600 back in the late '80s. I didn't know there were so many different screws.
Not really. These days I have a couple sizes of clutch head screwdriver bits in my screw driver / nut driver / allen driver set, but back then I just used a flat blade screwdriver that fit diagonally across the widest part of that bow-tie inset.
OK.
OK.
Next steps...
Well, now I've got some things to check once I get the engine compartment back together later this year! 1) verify physical operation of plunger mechanism and 2) prime the pump and line before trying again.
Thanks for everyone's input!
Rich
Rich
67BB
April 5th, 2013 01:07 PM
gregc
September 12th, 2010 07:43 PM
