Vacuum or Throttle part
Old Apr 9, 2023 | 12:34 PM
Skippie101's Avatar
what is this part called? As you can see i need to replace this. Is on a Olds 403 motor. Thanks
Old Apr 9, 2023 | 01:36 PM
It looks like the cruise control servo.
Old Apr 9, 2023 | 02:37 PM
That is a cruise control actuator. You are unlikely to find a new one.
Old Apr 9, 2023 | 04:41 PM
Skippie101's Avatar
Cruise control actuator
Thank you. As long as it doesn't effect the engine performance from the perspective of a vacuum leak then I can live without it. Thanks again.
Old Apr 9, 2023 | 05:24 PM
If you tried to use the cruise control it would be a massive vacuum leak. Plug the hose that goes to that actuator to be safe, but otherwise it won't have any effect on the engine.
Old Apr 10, 2023 | 04:34 AM
Skippie101's Avatar
Thank you. Appreciate your time and knowledge.
Old Apr 10, 2023 | 06:07 AM
69HO43's Avatar
IF you ever find one new, which is doubtful, the GM part number would be 551095 superseded to 12309832.
Good luck with that. It would be kind of simple for one of these restoration places to mold a new boot and diaphragm and devise a method for swapping it out, but you'd have to couple that with return on investment and demand, which likely isn't very good. IMO, unless absolute originality is paramount, I'd get a good aftermarket electronic unit to adapt to your car if you really desired cruise control. It sucks, but it all comes down to how much do you want to spend in time and money to do it the way GM did?
Old Apr 10, 2023 | 10:41 AM
Skippie101's Avatar
Yes thank you for that information. I agree, it would be a costly endeavor. Since there is no urgency, I will wait to see if I can find one from a salvage yard from a dryer climate state. Appreciate your reply.
76cutlass
Jan 30, 2023 12:22 AM
PT72drop
Jan 22, 2016 12:21 PM
babs68
Aug 14, 2015 03:46 PM
D Appeldorn
Jan 5, 2012 01:53 PM
woodie582
Nov 17, 2008 01:08 PM
