Speedo drive unit
Speedo drive unit
My new set-up has an early model TH-400 tranny so I need a speedo drive unit.
Can I get one to hook up to my 1985 Delta's axle and can I hook it up to the rear axle?
How do they work? Tire size a factor?
If you're talking about one of the motorized speedo drive units that allow you to use a cable drive speedo on an electronic trans, you're also S.O.L. These are designed to work with fully electronic transmissions like the 4L80E and require a trans that already has an internal speed sensor and a VSS output plug. The TH400 has neither.
Yes, both tire diameter and rear axle gearing will effect the speedo drive gear requirements.
Your existing speedo cable should attach directly to the speedo cable fitting in the TH400. If you have a TH400 out of a 60s Olds full size that used the front wheel to drive the speedo cable, you're S.O.L.
Is this plug a cup looking thing on the pass side of the tranny?
68RocketAction
December 18th, 2014 11:19 AM
tmaleck
September 23rd, 2013 01:47 PM
