simple radiator...not me?
Old Oct 4, 2006 | 02:08 PM
ztim's Avatar
I drained the radiator the other day. Then I refilled it. Now it wants to boil over so I have to let it cool down before adding fluid. What is wrong with it? Did I do something wrong?
1984 Delta 88
Old Oct 4, 2006 | 05:43 PM
ztim's Avatar
I think the problem is fixed. I opened the petcock and while it was draining, I put a hose in the top and let the water run. Then, with the water running, I closed the petcock and then shut off the water before recapping the radiator. After all that, I refilled the reservoir. If this works tomorrow, I will put the antifreeze back in.
Old Oct 5, 2006 | 04:45 AM
Oldsguy's Avatar
Past Administrator
you may have had an air pocket someplace in the engine block, air severely reduces the cooling capacity of a system. Hope you got it.
VikingBlue
Mar 1, 2010 01:39 PM
Allan R
Feb 13, 2010 10:43 AM
Red Delta
Sep 28, 2009 04:18 PM
tdubis
Brakes/Hydraulic Systems
Sep 6, 2009 08:25 AM
Olds403V8
Feb 2, 2007 12:11 PM
