Replacing heater core in F66 F85
Old May 23, 2008 | 05:25 AM
Colorado Olds's Avatar
Looks like we need to do this on Josh's '66 F85 - are there any tricks to it? This is a non-AC car. Looks like the housing might come off on both the engine side and the interior side? Any hidden bolts or screws?
Thanks,
Jim
Old May 23, 2008 | 11:15 AM
Thanks,
Jim
You will unfortunately need to remove the passenger side fender to get to the bottom outboard nut. The core is in the box under the dash, but you need to remove the nuts and screws from the engine side of the firewall.
Old May 28, 2008 | 02:36 PM
Run to Rund's Avatar
You should be able to get away with removing just the inner fender for access. Taking off the rf tire helps. I don't remember details as my 66s don't have heaters.
Old May 28, 2008 | 04:46 PM
The problem is that the 66 inner fenders are metal, not plastic. I'm not sure they bend as easily as the later ones.
71rocket
Feb 25, 2015 03:34 AM
Hammer7
Dec 24, 2013 03:31 PM
kitfoxdave
Aug 31, 2012 11:14 AM
ChefDeadpool
Body work
Nov 21, 2011 07:48 PM
delta881972
Apr 5, 2009 09:36 AM
