Need help - Should I buy this TIG welder?
Old Oct 15, 2013 | 09:19 AM
Rocket Richard's Avatar
I wasn't looking for this, but I found a guy on CL selling a Miller Dialarc HF welder for $150.
I haven't used a TIG welder before, only MIG and Oxy-Acetelene, but I've heard that TIGs are good for more accurate welding, and welding SS and Aluminum. I'd likely be welding only SS and CS though.
Also, at the moment all I have to power anything 220V is a dryer outlet. I would have to check the amperage available in the circuit. I only plan on welding sheet metal up to 16 gauge, so hopefully I can get what I need from that.
I don't know much about TIG welders, but this seems to be a good deal even if it needed a bit of repair work. Here's the link: http://vancouver.en.craigslist.ca/va...129823922.html
What do you guys think?
Old Oct 15, 2013 | 09:24 AM
Professur's Avatar
$150 .. Unless it's 3 phase, grab it with both hands
Old Oct 15, 2013 | 09:41 AM
gearheads78's Avatar
car guy
No. It will will be difficult to learn on and not have the ajustability to need to work on automotive type stuff.
A good used TIG is going to be $1500-2000 and expect to have another $1000.00 you will tie up in consumables and accesories.
Old Oct 15, 2013 | 09:54 AM
Professur's Avatar
http://www.practicalmachinist.com/vb...arc-hf-165153/
This one comes with the foot pedal already. Both hands I say... if it's working and not 3 phase
Old Oct 15, 2013 | 10:27 AM
Tony72Cutlass'S''s Avatar
I just bought a Mig-Pak 180 from lincoln at Canadian tire not too long ago.
I know it's not a tig, but so far it' sbeen able to weld through anything.
And you can buy the aluminum spool gun if you want.
Old Oct 15, 2013 | 11:44 AM
m371961's Avatar
I had a hard time reading the specs from the pic. Go to Miller site and read info, manual if available.
If it runs, has torchhead, cables and footpedal, it's a steal. But buying sight unscene and shipped it is a risk. If I saw it at a garage sale, I grab it even not working.
Old Oct 16, 2013 | 01:36 AM
Thanks guys,
Richard's comment about the consumables kind of raised a red flag. I don't want to get into something that will cost me a whole lot. I might just stick with my MIG. Just because it seems like a really good deal though, I still sent the guy an email asking for the model number.
Old Oct 16, 2013 | 02:55 AM
That unit looks BIG. You may not be able to use it for sheetmetal and small stuff.
Good price, though.
How much room have you got? You can't have too many tools.
Old Oct 16, 2013 | 09:23 AM
You're right, it sure does look like overkill for what I'd be doing. I'm assuming the adjustments would let me work on the small stuff, but I'm waiting for more info on it to confirm that.
I haven't heard back from the seller. This unit might be gone already. Gotta love it when they keep the ad up even though it's sold.
Old Oct 16, 2013 | 09:47 AM
Professur's Avatar
He marked it sold pending .... he's waiting for someone who called to show before closing it. It would go low enough ... but it's a whole lot of machine. With that, you'd never lack ... but your electric bill at the end of the month might make you cry.
Tig doesn't take much. You can grab the tail of a tig torch lead with your SMAW (stick) stinger, work your gas release manually from a bottle of argon and scratch starting is no harder than starting a stick ... there's nothing magical about it Given the lack of sparks and splatter, it's definitely worth knowing when you're welding up an exhaust inches from the gas tank. You don't need all the fancy bells and whistles to get the job done on cold steel.
Old Oct 16, 2013 | 10:06 AM
Here's a photo of my welder.
originally i bought a crappy 120V stick,
This puppy can chew through my frame quicker than oprah on a baked ham.
Flgaurban06
Sep 20, 2012 03:58 PM
Jim68-442
Body work
Mar 9, 2011 06:14 PM
tmbrennan
Jul 28, 2008 09:02 AM
BigBertha442
Feb 22, 2008 12:59 PM
shaks 442 clone
Dec 19, 2007 01:46 PM
