Jack ID
Jack ID
Was wondering if anyone could tell me if this is the right jack for a 72 Cutlass. I still need the hook but wanted to make sure the hook would fit on this jack first. My car came with two jacks. The other is in worse shape and a little bit different.
That was kind of what I wondered. I'll get pics up on my other jack. Hopefully it's the right one. Right now I have a cylinder jack that's rattling around. I figured the stock jack would be more secure.
Jack Hook
The second one looks like the correct type. I would get the hook for it, restore the jack and screw it into the trunk as per factory, then leave it there. The hook will dent your bumper and the jack itself may dent your head. They are not stable or safe for that matter. I would keep a more modern screw jack or even a
small hydraulic jack for actual usage. Also, make sure everything is secured in the trunk, nothing worse than a dent from the inside of your rear fender poking out. If you manage to find a source for these old type of jacks, keep us posted.
Not one person here with a 1972 Cutlass is willing to go open their trunk and get the jack out and snap a few pics of it?
Come on guys.
Are there any part numbers on it? The correct jack handle/lug wrench should have a small raised letter "O" on it IIRC.
X2 on not using the thing, they destroy bumpers, the front especially. You just tap those bumpers into tall grass at a mile an hour and it will bend it up into the classic "Cutlass grin".
I have a medium size floor jack in a plastic storage case that I carry in my OCC's third seat footwell.
That is not correct for a 72 Olds A body. The lift point on the jack suggests 73 or later.
