Heater core & evaporator advice
Old Feb 19, 2018 | 05:51 PM
cdrod's Avatar
Rodney
I'm close to the stage in my rebuild where I will need to reassemble the HVAC system and reinstall the evaporator suitcase. I have a a couple of questions hoping for advice from those that have gone before me.
1. Most of the replacement heater cores now are made from aluminum. Am I better off with a new aluminum core or should I have a radiator shop re-core my existing copper heater core? I will have an aluminum radiator and aluminum intake manifold, do I reduce the effects of electrolysis by installing an aluminum heat core instead of a copper core?
2. Can I pressure test the evaporator and reuse it if it tests OK, or should I replace it with a repop part? Can a radiator shop pressure test the evap core or should I take it to an AC shop?
My project has also reached critical mass in regards to the budget so saving $$ where possible is important but not if it affects dependability. Thanks!
Old Mar 16, 2018 | 09:34 AM
banny's Avatar
I haven't had any issues with the aluminum heater cores ive installed in the heater boxes that I restored. You can flush and pressure test the original evap. I do it many times. Just have to check with shops if they can do it. Some my gm restored units https://www.youtube.com/playlist?lis...FKMMKfybxmuIeJ
Old Mar 17, 2018 | 12:27 PM
ropewrench's Avatar
summit racing
Summit sales a copper core
501Paratrooper
Apr 23, 2014 06:26 PM
westside807
Apr 21, 2014 02:20 PM
1arunem
Sep 3, 2013 07:32 PM
Lady72nRob71
Jul 30, 2011 08:14 PM
jeffs 89 cutlass salon
Oct 22, 2007 12:46 PM
