Heater Control Valve
Old Nov 12, 2017 | 01:08 PM
cus's Avatar
cus
Hello,
I've removed all the a/c from the 350, I've just retro fit an aftermarket heater/demister under the dash. I've connected up the heater hoses, from the control valve to the heater & the hose back to the pump. My old control valve has no vacuum hose connected. I have an in-line on/off valve in the
feed hose that I can cut off flow to the core when I wish. Seem to have restricted flow though, is it because of no vacuum on the control valve?
regards, cus
Old Nov 12, 2017 | 01:25 PM
Originally Posted by cus
Hello,
regards, cus
It depends on the year and model (which you did not tell us). For the A-body cars, 1972-earlier have normally closed valves that require vacuum to open. 1973-up have normally open valves that require vacuum to close.
For the full size cars, 1970-older have normally closed, 1971-up have normally open.
Of course, if someone installed the wrong valve, all bets are off.
Old Nov 12, 2017 | 02:00 PM
cus's Avatar
cus
Thanks Joe,
Car is a 1973 Delta 88, valve looks pretty original
Old Nov 13, 2017 | 08:26 AM
Thanks Joe,
The original valve for a 1973 D88 is normally open and should present no restriction without vacuum applied. Are both hoses to the heater warm when the engine is warmed up?
Old Nov 13, 2017 | 12:45 PM
cus's Avatar
cus
I investigated more last night, flushed the heater core, hooked up to the manifold,
all was flowing OK, was blocked at the water pump, had calcified a bit in the base of the tube, cleaned out & presto, has been bunged off for quite a few years I think.
Thanks for your help
jensenracing77
Mar 19, 2014 04:08 PM
zodiacblueS
Apr 7, 2012 02:38 PM
Mister
May 13, 2011 03:53 PM
blue72regency
Dec 12, 2007 01:12 PM
bjtstarfire
Dec 15, 2006 10:14 AM
