Heat works but blows cold?
Old Mar 3, 2013 | 06:39 AM
FinkD88's Avatar
I was going for a ride last night in my 1979 Delta 88 Royale two door coupe and the heater went from blowing hot air to cold. If I have the heater off and have the air temp on hot, hot air comes into the car. But as soon as I select heater and turn the fan on it goes from hot to cool. Any help as to why this is happening would be appreciated.
Old Mar 3, 2013 | 07:13 AM
You've got a loose air temperature flapper door - it's blowing closed when you put the fan on.
Others (or your Chassis Service Manual) can tell you exactly where the cable (or vacuum pot) and lever are for the door, but they are generally up behind the middle of the dash or the glove compartment.
Old Mar 3, 2013 | 07:14 AM
tru-blue 442's Avatar
Old School Olds
Maybe low on coolant?
Old Mar 3, 2013 | 10:03 AM
FinkD88's Avatar
Thanks for the help!
Old Mar 3, 2013 | 10:25 AM
Old School Olds
So you figured it out?
What was it?
Old Mar 3, 2013 | 12:05 PM
Do you have the Temptronic automatic climate control or not? If not, then the problem is a common one. The 1977-1990 B/C-body cars like yours (and the 1978-88 A/G-body cars, which use the same design) have a cable-actuated heater blend door with a plastic actuating bellcrank that usually breaks. Remove the glovebox liner and you'll see the bellcrank and the cable end. Replacement bellcranks are no longer available, so if this is the problem you'll need to repair your old one with epoxy and reinforcements.
If you do have Temptronic, the problem is likely the programmer unit also located behind the glovebox.
Old Mar 5, 2013 | 09:35 AM
FinkD88's Avatar
No, I haven't fixed it yet but if I get a chance I'll take out the glove box insert and take a look at the cable-actuated heater blend door and see if the bellcrank is the problem. Eric and Joe thanks for the help, I had no idea where to even start.
MudEye
May 4, 2015 05:06 PM
rum1
Aug 17, 2012 12:54 PM
White Spyder
Jul 31, 2012 05:59 PM
bmichener
Feb 17, 2012 08:38 AM
71supreme
Nov 2, 2010 09:10 PM
