Headers
Old Sep 22, 2008 | 01:00 PM
woodie582's Avatar
Headers
I like everything I read about Dougs headers for my 71 350, cept it seems they dont do the 350. I wanna remove the cheap rust tubes I have and replace with a coated quality part. Recomendations...Thanks
Old Sep 22, 2008 | 01:26 PM
Oldsguy's Avatar
Past Administrator
I think this may help you out.
https://classicoldsmobile.com/forums...ompletion.html
Old Sep 23, 2008 | 01:07 PM
woodie582's Avatar
Thanks Olddude, I mean Oldsguy. I went with the hedman shorties.
Old Sep 24, 2008 | 01:30 PM
woodie582's Avatar
Hello :
Before we start, I want to confirm that this car is not a Cutlass Supreme. If you have CS, this hedder will hang too low. We make another hedder for CS's, part number 58190.
So, if you have a standard Cutlass, it’s a straightforward install. The only hard part is you have to unbolt the passenger side motor mount, and raise the engine to get the old exhaust manifold off. You just remove the manifold, then lower the engine and install the hedder.
Thank you,
David
This is Hedmans reply to my header fitment question. I'm going with plan that they are wrong..
Old Sep 24, 2008 | 02:05 PM
Good plan
Old Sep 24, 2008 | 02:59 PM
smcurro's Avatar
Is there anything about the Cutlass Supreme that makes it different from the Cutlass when it comes to fitting headers? I have a 70 Supreme and a bunch of header companies such as hooker say they only make headers for the 70 Cutlass and that the headers won't fit the Cutlass Supreme...sure sounds like BS to me...
...You just remove the manifold...
yeah just remove the manifold...no big deal...those bolts won't break or be stuck...
Old Sep 24, 2008 | 03:12 PM
woodie582's Avatar
smcurro, I've researched, asked and read alot on the header subject. The only people who say they wont interchange are the manufacturers. What do they know? Experienced folk say they work.
Old Sep 24, 2008 | 03:30 PM
This topic has been covered repeatedly (nearly as often as the motor mount topic) on all the Olds boards. I have personally measured the engine location in a Supreme. There is no offset. The motor mounts and frame mounts are the same as on a Cutlass. The frame is the same. There is no logical reason for this disclaimer. Many folks have installed regular Cutlass headers with no problems (other than the usual header installation problems). You nearly always must move the brake distribution block. Starter clearance will be tight. The backdrive linkage to the trans may or may not fit, depending on the header brand. None of this is unique to the Supremes.
Old Sep 24, 2008 | 04:05 PM
smcurro's Avatar
That sounds very logical...Thanks Joe! Also sorry to ask a well documented question, I didn't think to search for it before I asked...
Old Oct 12, 2008 | 01:39 PM
woodie582's Avatar
Headman shorties have been on for a week. Good fit, oil filter, clutch linkage and starter all wide open now.
Wyze
Mar 18, 2012 01:59 PM
martine
Feb 13, 2007 11:57 AM
JoshF85
Jan 24, 2006 10:20 AM
javi58
Apr 20, 2005 07:53 AM
<72>
Nov 11, 2004 09:09 PM
