fuel pickup sock
Old August 9th, 2015 | 08:03 AM
biggus's Avatar
fuel pickup sock
Last weekend I parked my 68 Cutlass Supreme on a slight angle in the parking lot and when I came back out it had leaked a small amount of fuel. So great, a hole in the tank so I pulled it. Turned out to be the fuel vent hose was cracked, easy fix. Do these two vent hoses just kind of float around up in the RR spring area? Then i took out the pickup to see why my fuel gauge wasn't working and with my ohm meter seen the numbers were changing as I moved the float so I assume the sending unit works. The problem is the fuel sock-filter on the pickup disinigrated when I touched it. Just took it off. I've got an in line filter will this be a problem? From what I've read on here they aren't replaceable without replacing with a new mickey mouse chinkaneese unit.
Old August 9th, 2015 | 10:11 AM
jaunty75's Avatar
It would be very helpful to know what car we're talking about here.
Most likely, yes, but they're clipped to the underside of the body. That's how they're arranged on my '67 Delta 88. Do you have a factory service manual?
I wouldn't automatically assume that a replacement fuel gauge sending unit will be bad. Many people, including me, need them, buy them, install them, and they work just fine. Spectra-Premium is a common brand. I put one in my '67 Delta back in 2009, and it has worked fine ever since. I bought it from rockauto.com.
Old August 9th, 2015 | 10:12 AM
bob p's Avatar
Rocketeer
I just bought a fuel sock on ebay. $10. Works fine.
looneyman
May 31st, 2015 09:37 PM
MDchanic
April 6th, 2013 06:57 PM
Twilight Fenrir
July 22nd, 2011 05:22 PM
Lady72nRob71
June 26th, 2008 03:47 PM
