Exhaust manifold trouble
Old Jan 4, 2008 | 05:54 AM
HELP! I am tearing apart my 455 and when I took the pipes off of the exhaust manifolds 3 bolts broke off and are stuck in the manfold. The bolts are broken off flush with the manifold surface. There is about 1/4" of the bolt sticking out of the opposite side of the hole. What would be the best way to get these out? Should I try an EZ out, or should I drill them out with a larger drill bit and put a HeliCoil in? Someone at the auto tech center on base said I should heat them up with a torch and try to get them out the back of the hole with a pair of vise grips. I think the bolt would just smash and the threads would get damaged. I have never had any luck with vise grips. I will take some pics tonight if I get over to the auto tech center.
Old Jan 4, 2008 | 06:24 AM
I assume you're talking about the bolts at the exhaust pipe flange? I've had very good luck with the heat and vice grips method. Be sure to get the manifold ear red hot and thread the stub out the backside. Failing that, the Helicoil is the next solution.
Old Jan 4, 2008 | 12:29 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Or you could just buy another one from someone on R.O.P. dirt cheap.
They probably have piles of them from header swaps.
Think about it, if it's going to take you 3 hours to mess with plus a mapp gas cylinder.
Assuming you want to pay yourself 20 bucks an hour for labor, $60 bucks is guaranteed to snag you a good mani.
Old Feb 6, 2008 | 10:58 AM
Oldsguy's Avatar
Past Administrator
Hey son, I found this over at the HAMB. good luck
http://www.jalopyjournal.com/forum/s...0425&showall=1
Old Mar 29, 2008 | 10:05 AM
Run to Rund's Avatar
Maybe your car is telling you to upgrade to the branched manifolds
Kroil or Mopar rust penetrant might help, heat usually helps if you get it hot enough. Next time use good grade 8 bolts and Never Seez.
atkinsom
May 29, 2013 06:39 PM
RussTad
Aug 17, 2006 12:42 PM
Oldsguy
Aug 11, 2006 06:44 AM
DonFrost
Ninety-Eight
Jun 22, 2006 04:16 PM
