Column shifter
Old Aug 15, 2022 | 05:05 PM
NorthBay72supreme's Avatar
Column shifter
Recently bought a beautiful billet shifter which ended up not fitting. Universal fit my ***.
Now I can’t get the OE shifter back in. I can partially insert it and shift from park to R to neutral, but that all done with the pin installed that holds the shifter in place. SOS
Old Aug 16, 2022 | 05:24 AM
70sgeek's Avatar
'72 Cutlass ragtop
so to reaffirm - you can currently shift the column from Park thru neutral with the factory lever fully reinstalled but not into drive? or are you saying the lever won't go fully back in to where you can reinsert the pin?
Is that a factory tilt or non-tilt column? I'm assuming non-tilt because you have a non-tilt shift lever (the tilt lever is not as long at the end and squared off at the tip, no point - they're not interchangeable but you can easily grind the point off to where it will work on a tilt-column.
Old Aug 16, 2022 | 05:30 AM
Your Chassis Service Manual shows you how to insert a shim into the shift bowl to depress the spring before you insert the shift lever.
Old Aug 16, 2022 | 06:17 AM
Its not fully installed. I can get to neutral with the shifter partially seated. Can’t reinsert the pin. And yes, non tilt.
Old Aug 16, 2022 | 06:19 AM
Thanks Joe I’ll take a look. I fumbled around with the assembly manual, got frustrated, and posted. I’ll check it out.
Old Aug 16, 2022 | 05:42 PM
Hey Joe any bright ideas on what I can use for a shim? I’ve tried and Allen wrench and a jig saw blade with no luck.
Old Aug 17, 2022 | 12:15 PM
I can partially insert the shift lever and cycle from P to N. But I cannot fully insert it where I can reinsert the pin.
Old Aug 17, 2022 | 07:24 PM
70sgeek's Avatar
'72 Cutlass ragtop
how about a really thin long shank / small sized flat blade screwdriver - something along the lines of a jeweler's tool
Old Aug 17, 2022 | 08:22 PM
For a long, thin, flat, strong piece of metal I use the metal strips out of wiper blade refills.
Old Aug 18, 2022 | 04:12 PM
Guys I got it. Went to a salvage yard and bought various gauges of scrap metal. This sucker did the trick.
Hoffman2099
Nov 30, 2017 06:15 PM
88hurstolds
Dec 28, 2015 02:43 PM
budgdawg
May 25, 2011 06:56 AM
gabes455olds
Mar 27, 2008 08:00 AM
TheRuss
Jun 4, 2007 01:28 PM
