A/C Help
I have a 1985 Toronado. Neither the AC or Heat works. If I set it to vent, I'll get a little bit of air, alot from the middle-bottom vent(sometimes). On any other setting there is no air at all. If on anything other than vent, I hear pressure escaping from the control box. Anyone know what the problem could be?
Sounds like your problem is with the mode door which determines where the air will be directed (defr, htr, ac outlets, vent, etc). Some model have the mode door diaphragm open or closed with vacuum or the opposite of being spring lodaded and open or closed without vaccum. Probably a hand vaccuum tester to determine if the door is working and a vacuum diagram would be helpful which is usually printed in the Olds shop manual or thru MOTOR manuals or Chilton or Mitchell.
Good luck
Jerry
Good luck
Jerry
PS you might be able to get a vacuum diagram thru MOTOR.com...they are suppliers for ALLDATA and their data base goes back to 1982. If no luck on the internet then go to a nearby shop of which most have Motor/Alldata, Alldata or Mitchell on their PC and you can probably get a printout of the diagram for a nominal or no fee.
Good Luck
Good Luck
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
