Added front Shoulder Belts to my 71 cutlass convertible
Old Jun 1, 2025 | 04:48 PM
lshlsh2's Avatar
I found this kit from OPGI but ordered it straight from the company Morris Classic Concepts.
​​​​​​https://www.morrisclassic.com/produc...44422707839276
The kit was pretty easy to install. I did it in a couple of hours, It was a little easier for me because I had most of my interior already removed. The one thing you need to get is a really good drill bit for Metal. It installs using factory mounts. Just have to drill 1 hole. When I reinstall the interior I will have to notch part of the rear cover,
Old Jun 1, 2025 | 04:54 PM
lshlsh2's Avatar
My old belts
My old belts
The new belts.
The new belts.
Lots of metal shavings from drilling the hole.  I would recommend taking the rear seat and carpet out.  Makes clean up easier.
Old Jun 1, 2025 | 05:04 PM
lshlsh2's Avatar
The rear bracket installed.  It is formed aluminum about quarter inch thick.
The bottom of the belt.
Matched up pretty well with my interior.
Old Jun 1, 2025 | 05:10 PM
lshlsh2's Avatar
If anyone wants more pics let me know.
I did take a ride after they were installed about 70 miles. They were comfortable, better than I thought they would be.
I also hope I never have to give an update how they work in an accident.
Old Jun 2, 2025 | 05:11 AM
riverolds's Avatar
Nice work, nice kit. Is there any trim for the bracket that sticks up over the rear quarter and the belt mount and bolt, or is it all exposed?
Old Jun 2, 2025 | 05:18 AM
riverolds's Avatar
Does the kit include new lap belts, too, or do you re-use the old ones?
Old Jun 2, 2025 | 05:37 AM
lshlsh2's Avatar
The bracket sticks up. May paint it later but doesn't look to bad.
The seat belt is one piece lap and shoulder. So no need for the old belts.
Old Jun 2, 2025 | 05:51 AM
68442CONVERTCO's Avatar
Aloha, Tony
Old Jun 2, 2025 | 05:52 AM
Aloha, Tony
Pic from Morris website.
Old Jun 2, 2025 | 06:12 AM
I remain skeptical of aftermarket seat belt kits like this. GM crash tested cars to verify that the factory belts met federal standards. Shoulder belts were a factory available option for convertibles. They didn't mount with a bracket like that. Ask the supplier how many crash tests they've done on their product. Like TSA, they definitely provide the APPEARANCE of security.
Old Jun 2, 2025 | 07:38 AM
lshlsh2's Avatar
I realize that they may not be perfect and probably screwed in the event of a bad accident. In the event of miner accident like hitting a deer like I have multiple times where I live don't want to pick the steering wheel out of my teeth.
Old Jun 2, 2025 | 07:40 AM
lshlsh2's Avatar
Oh it is a tight fit but the window and the top will go up and around the bracket.
Old Jun 2, 2025 | 07:47 AM
Last time I hit a deer at high speed (in excess of 40 MPH), the deer went flying. The airbag in the car didn't even go off. A white-tailed deer runs 100-150 lbs. Physics suggests that a 3,700 lb car isn't going to be slowed down significantly if you hit one.
Old Jun 2, 2025 | 08:57 AM
oddball's Avatar
How's the OEM shoulder belts work on the vert?
Old Jun 2, 2025 | 10:37 AM
Precisely. People wrecking because of deer do not wreck because of the deer; they wreck because of swerving to miss the deer. If you see a deer, brake, but do not swerve. Steer around it in a controlled fashion, and rest assured you will win over the deer should you hit it.
Also, if you see a deer, the first thing to do is deal with missing it. The second is look for its buddy as they usually are in groups.
Old Jun 2, 2025 | 10:56 AM
OLDSter Ralph's Avatar
I hate to say it, but deer aren't usually standing alongside the road waiting for a time to safely cross the road. They usually stand in the edge of their habitat concealed. When "they" decide to cross a road, its suddenly bolt toward the road at a full run.
I have hit the head and front shoulder with the passenger side grill, headlights, fender and door. Another one was broadside and damaged the complete front grill, passenger headlights, passenger side fender and inner wheel well.
Old Jun 2, 2025 | 01:12 PM
lshlsh2's Avatar
I guess I should have said a fender bender.
When I was in high school I had one jump off of a hill next to the road and land on the roof on my Chevy citation.
I guess we grow our deer bigger over here. During hunting season we regularly hear of deer well over 200 pounds. Last year a hunter on my property took a 202 pound doe.
Old Jun 2, 2025 | 01:50 PM
Do the math. 200 lbs still isn't going to slow down a 3700 lb car very much.
Old Jun 4, 2025 | 12:30 AM
GCH's Avatar
GCH
Very intresting Joe , thanks for pics have thinked about how this was mounted in a convertible.
Was this an option in 1965 also ?
Old Jun 4, 2025 | 03:55 PM
I believe that 1967 was the first time that the optional shoulder belts were offered.
Old Jun 4, 2025 | 04:54 PM
GCH's Avatar
GCH
Ok , thanks for info
Old Jun 8, 2025 | 05:13 PM
lshlsh2's Avatar
With the new seat belts in, I took my granddaughter out for her first ride.
Old Jun 8, 2025 | 05:32 PM
cjsdad's Avatar
Did $7K damage to a coworkers F-150 in Northern Az. one night a long tome ago. And turned his trousers brown...
Rocketbrian
Jan 16, 2021 06:37 AM
Sircajun
Jun 16, 2014 02:34 PM
Custom68
Jun 13, 2012 06:58 PM
Ddbord
Jul 12, 2010 09:54 PM
stevengerard
Sep 26, 2009 08:59 AM
