65 starfire
Old Jul 16, 2006 | 04:43 PM
phantom.10's Avatar
65 starfire
Looking for the correct date year heads and a intake for my 65 starfire..
Any info on repairing a leak in the heat riser valve ???
Old Jul 16, 2006 | 05:05 PM
texasred's Avatar
Tom Servo's Stunt Double
If it's a 330, heads are B = 385101.
400 and 425s are C = 383821
Sorry I can't help you on the intake or heat riser.
C.J.
Old Jul 17, 2006 | 06:42 AM
Oldsguy's Avatar
Past Administrator
If you are talking about the valve in the exhaust manifold, those are really prone to rusting up as any component is in the exhaust sytem. Your best bet would be to try using some PB Blaster or similar agent to break the rust loose. Apply it to the shaft the valve is mounted to and the pivot points in the manifold itself. Of course this means removing the exhaust to get to the inside. Apply this stuff for three or four days a couple of times per day before you ever try to move the valve, let it get a good soak. Then try to move the valve on it's axis, hopelfully you will be able to break it free without any damage, then just reassemble the manifold to the head.
Old Jul 17, 2006 | 02:56 PM
phantom.10's Avatar
Thanks Oldsguy...will do
1962oldsguy
May 19, 2019 08:08 PM
Kyle's 77 Cutlass
Jan 1, 2014 09:06 AM
Oldssupreme
Feb 3, 2013 06:26 AM
Oldssupreme
Feb 3, 2013 06:24 AM
slhandpaz
Oct 24, 2005 05:17 PM
