1970 Cutlass w31 hood latch/louver stuck
Old Oct 1, 2019 | 10:13 AM
Wessidetempest's Avatar
Hello. I’m desperate here and can’t find an answer anywhere.
I have a 1970 Cutlass W31 that I inherited from my father and was his baby. It has the hood release and latch on the front and two pins on either side. They are spring loaded so when you turn/release it pops up.
Well one does not pop up and is stuck. I’m guessing the spring got stuck on the surrounding.
I’ve wiggled, jiggled and cursed 100x over. I can’t figure out how to access it from another way.
Any other recommendations?
desperate in Detroit
Old Oct 1, 2019 | 10:42 AM
VC455's Avatar
Barely Registered
The retainer pin has shifted in the shank of the hold-down. Refer to https://classicoldsmobile.com/forums...n-shift-24315/
Some have used a pliers (with padding) to forcibly tun the Hood Pin and bend the retainer pin. You can then open the hood, remove the Hood Pin and replace the retainer, making sure ti can't move this time!
There may be alternate solutions, which others will chime in with.
Old Oct 1, 2019 | 10:46 AM
scrappie's Avatar
Common failure of the pin dislodging. There has been discussion of this problem before here. I tried searching the forum but no luck. Be patient, someone will chime in.
Nice car BTW
Old Oct 1, 2019 | 12:59 PM
Ugghhhh I feared that was the only way to open. Which I did. And hood is up.
Thanks everyone for the help and being patient with the newbie.
I’m not sure if I’d trust the hole that held the pin as it looks compromised from forcing it open.
Looks like I’ll be replacing it.
Old Oct 2, 2019 | 07:11 AM
akspeedy's Avatar
congratulations on inheriting one bad *** machine, the hood pins can be tricky good luck, you've come to the right place for guidance, members here are more than helpful, welcome!
Old Oct 2, 2019 | 07:18 AM
VC455's Avatar
Barely Registered
Congratulations on getting the hood open. That has to feel better.
The paint on your car looks amazing. Post a full picture of the car for us to Oooh and Aaah over!
It may be an artifact of the photo angle, but there does not appear to be a scuff plate below the hood pin. I've had two original W-25 hoods and both had stainless steel plates glued on the fiberglass below the hood pin.
Edit added after a closer look: I see there may be a painted scuff plate under the pin.
Old Oct 2, 2019 | 12:06 PM
WTHIRTY1's Avatar
Escape From The Ordinary
The retainer pin has shifted on the pin itself. It's a major pain to try and push that pin back. You can try to twist the hood pin, but there isn't really an easy solution. Can you get to the pin from underneath?
WTHIRTY1's Avatar
And let's hear more about your w-31. Check out w31registry.com
Old Oct 4, 2019 | 10:48 AM
It is possible. I don't ever remember seeing a plate between the hood latch and the actual hood. The new ones did come with a scuff plate.
Now I am trying to figure out best method of getting the in and out.
Old Oct 4, 2019 | 10:51 AM
No can't access it from anywhere. I tried that first. Behind the light, etc. There is some sort of metal lip that attaches above the radiator that goes over the front of the car. If that wasn't there you may be able to access. But in reality even if that is gone I am not sure you'd be able to reach it and then have enough leverage to turn it the way it needs to go.
Old Oct 4, 2019 | 10:55 AM
wOw. Thanks never knew about this. Wish my dad would have seen this.
Ecpirate
Oct 29, 2015 03:50 PM
72cutlassolds
Sep 1, 2014 08:29 AM
mruders
Jul 17, 2014 09:57 PM
Olds luvr
Nov 9, 2013 09:19 AM
georgiaboy697
Jul 2, 2010 09:23 PM
