93 honda accord 4 dr se model
My front passenger side wheel is slightly tilted. I hit a curb on the left side. I blew the tire out after it happened. I replaced the upper ball joint, but didn’t need to. It didn’t fix the problem. Took my car to get a front end alignment and was told my steering knuckle is bent. I know something is, but not sure what. They quoted me $450 to fix it. I got a knuckle from the wrecking yard with abs because my car has abs. After having it installed, I went back to get a line up but was told the knuckle is bad. You can’t tell if one is bad just looking at one. I am frustrated because this is my daily commuter. I need the left front tire straight just like the right side. I know this is easy to fix but just not sure what’s causing the problem. I don’t like playing guessing games. Any help is greatly appreciated. Not sure if the part needs to come off of se model the same as mines. Does it matter if the part is from a 2 or 4 door?
CyberCholo
Jun 1, 2014 05:33 AM
2stolencars
Jan 30, 2008 11:32 AM
