Non-Oldsmobile Classified Please read forum guidelines before posting.
1970 Pontiac Lemans
Old Oct 16, 2018 | 10:41 PM
72cutlassdog's Avatar
1970 Pontiac Lemans
I have an opportunity to purchase a 1970 Lemans for a good price. It's a column shift bench seat car. I don't want another bench seat car and prefer bucket seats. My question is what do I need to do to convert from bench to buckets? I would also change the column to a tilt. Thanks for the help.
Old Oct 17, 2018 | 05:23 AM
A Lemans is just like any other A body. Just swap out the seats, column, and install a floor shifter.
Old Oct 17, 2018 | 06:18 AM
droptopron's Avatar
delete
These days, if you want to find clean factory used parts it gets to be a pretty expensive proposition. Look around and price things out before you get started.
Old Oct 17, 2018 | 07:39 AM
I forgot to mention the part about I would add a floor shift. What are the steps to converting from a column shift to a floor shift?
Old Oct 17, 2018 | 08:53 AM
It all depends on whether you go stock or not.
Old Oct 17, 2018 | 09:26 AM
It will be stock.
Old Oct 17, 2018 | 09:41 AM
droptopron's Avatar
delete
1st you need to source the parts. Console, mounting brackets, shifter, wiring harness, cable & cable bracket. For the buckets you'll need the seats with tracks and the mounts that need to be welded to the floor, You'll need a floor shift column from a 69-72. Maybe a new speedo (not sure on Pontiac). I may be leaving some stuff out.
https://www.ebay.com/itm/1966-1972-C...voFH:rk:5:pf:0
DRoger5739
Mar 17, 2019 07:57 PM
matchek
Jan 15, 2017 07:16 PM
ManCutty
Jan 6, 2016 05:01 AM
oldsmobilty
Jan 19, 2014 11:03 AM
nooldsyet
Feb 16, 2013 12:44 PM
