Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
1978 Delta 88 Build
Old February 19th, 2014, 11:35 AM
warnej21's Avatar
1978 Delta 88 Build
So im hoping soon to start my build on my delta 88 in the next few weeks after all this snow melts and its warm enough to start going out and finding parts. Any of you guys have suggestions for motor mounts while swapping out a 350 olds for a 400 sbc?
warnej21 is offline
Old February 19th, 2014, 11:56 AM
mike's88's Avatar
Nope
mike's88 is offline
Old February 19th, 2014, 12:02 PM
Chevy budget Olds powered
coppercutlass's Avatar
I would build the 350 or go 455.
coppercutlass is offline
Old February 19th, 2014, 12:25 PM
Proud Viet Nam Veteran
redoldsman's Avatar
What about an Olds 403. If you want a SBC, that will be easy since they were also used in Delta 88's.
redoldsman is offline
Old February 19th, 2014, 12:27 PM
warnej21's Avatar
the 350 in it is a terd, and a sbc swap will be perfect for what im doing with the car. Plus im getting the 400 the price of splitting some wood for a guy. Also there's more aftermarket parts cheaper for sbc
warnej21 is offline
Old February 19th, 2014, 12:34 PM
Its all relative. I have built some small block olds on a tight budget but if you are getting a 400 all you gotta do is find the motor mounts from a 305 of the same era and run em. You may have to move the frame mounts. I would then treat it like a chevy and find a chevy forum for the engin info. Most guys here are die hard olds.
Old February 19th, 2014, 12:58 PM
I moved your thread to the non-olds powered forum because of your Chevy transplant.
I put a BBC in my A body so I'm familiar with the most of the requirements. Your going to need a Chevy transmission also. I'm not sure what frame brackets will work on your car, but if Redoldsman is correct then it's a no brainer. You will need all the accessory brackets for the sbc, and a few wiring and plumbing changes.
oldcutlass is offline
Old February 19th, 2014, 01:01 PM
warnej21's Avatar
alright cool and ya i got a th350 with the motor and a corp 10 bolt with a mini spool already in it
warnej21 is offline
Old February 19th, 2014, 01:05 PM
I had a 350 sbc in a 79 pontiac boneville I had to relocate the frame mounts not sure if its the same for olds but the 305's also came in the pontiacs. The weird part is we took out a buick 350 and installed an olds 350 in my dads 77 pontiac bonville and we didn't have to move the frame mounts. Just my experience.
Old February 19th, 2014, 01:10 PM
warnej21's Avatar
Sweet. im also getting a racing seat, fuel cell, battery box from the same guy. also got a new 5 point harness and tach. cage coming soon
warnej21 is offline
Old February 19th, 2014, 01:12 PM
Then you just need some frame brackets. Should be an easy bolt in. I believe you can use the frame brackets from an Impala or Caprice.
agreen316
December 21st, 2013 06:27 AM
wildwillie1981
April 24th, 2013 04:19 PM
Joepapworth
October 30th, 2007 04:51 AM
69 442 protour
December 9th, 2006 09:25 PM
dcoymb
December 6th, 2006 09:31 PM
Quick Reply: 1978 Delta 88 Build
