What non Olds builds do have going on.
I got a good one going on.. a 1974 AMC Hornet 4 door sedan, with a Vortec headed/mildly built 350 chevy engine, a MY6 3 spd. overdrive stick shift...[yes, it's a truck trans. Essentially an A833 dodge 3 spd. OD trans. in a chev case. Same ratios as a TH700R4] going to a Ford 9" rear with 4.11 gears. On these are Dodge full size van rims. Yes, it's an AMC .. or .. All Motors Combined. It started life as a 232 with AT, but that was way too boring. My intent is/was to recreate the Mad Max Yellow Interceptor car. The car is factory yellow with the tan interior. I even grafted the roof spoiler on, as in the movie. It still need the chrome spoke wagon wheels and the rest of the red and blue paint.
However, the car will be going up for sale as an untimely family matter forces the sale of the car. I'll be posting a video on youtube soon, to help advertise and sell the car. Comes with all sorts of extra stuff, including the scooped hood and ram air air cleaner set-up. Cheers, Mike
helping my uncle with a 54 ford frame off,that now has the frame modified with a S-10 front frame section for the disk brake setup and guess what---A Small Block cheby
I built the engine already and is sitting on the stand waiting.a 383 stroker with older big style edelbrock heads.
were swapping the rear right now with a 9" and rewelding all the mounts.
also bending up new brake lines to replace old rusted ones on a 64 ragtop chev impala for my other uncle!
I built the engine already and is sitting on the stand waiting.a 383 stroker with older big style edelbrock heads.were swapping the rear right now with a 9" and rewelding all the mounts.
Finished putting a new AAW Highway 22 kit in my 78 Pro-touring Z28.
http://www.nastyz28.com/forum/showthread.php?t=162255
Now I just have to get the damn LS1 to start. LOL
I have two right now. One is for a friend he has a 78 Bronco. I'm building him a 460 to go in it. I'm going to have to do some rewiring, bodywork, and we will see how much money he has left over and go from there.
The other one is for my nephew he has an 83 GMC 1500 4x4. That needs a lot of work, his dad going to help him most of it. My main thing is going to help with deciding what parts to buy. He has some weird ideas on what works, but he's only 15 and this is his first build.
As always my Cutlass is first on the list to fix, but if I can make a little money on the side. Then why not.
I like all the makes but I grew up in a Ford town , Lorain , Oh. ...
I have a 68 Cougar but it has to wait for a couple of other little projects to get done before we actually start taking everything apart(Hopefully within a month). I already have a 460 block and a couple pairs of heads and a few cranks to pick from.
Sorry, this thread is so old I must have missed this part.
It ended up being bad gas. I had to drain my new tank, fuel lines, and fuel rails.
New project is Piecing together my custom stereo setup in the same car.
My 10" sealed custom sub box I just made with the Boston Acoustics sub.
Top is wider for carriage bolt supports, bottom is wider because it's 2 amp trays.
This will hang from under my package tray in my trunk. Same setup going in the Olds 2011.
Custom package tray I just made out of hardboard and premium vinyl because the OER package trays are crap.
No pics, but I'm always working on my Alero. I know it's an Olds, but it's got the 60* V6 engine which is a Chevy based motor.
I have on the engine right now:
Stage 2 P&P upper and lower manifolds
Headers & Full Exhaust
Cold air intake that I convert to a warm air for daily street use
mild P&P heads
>>> milled .020 roughly 9.7:1 CR
>>> 3500 valves
>>> 3 angle valve job
>>> LS6 springs
Sitting in my closet:
bottom end 3400 motor with 159,xxx miles
narrowed SBC rods
waiting on:
Comp Cams camshaft
259/265 adv duration
210/216 .050" duration
.506"/.506" lift @ 1.6:1 Rocker Ratio
113 Intake Center Line
114 Lobe Seperation Angle
going to get:
double roller timing chain (crank had to be modified for this)
crank scraper
Diamond forged pistons, looking at .020 over and 10.5 : 1 CR
some other things that I can't think of right now
mild P&P heads
>>> 3500 valves
>>> 3 angle valve job
>>> LS6 springs
narrowed SBC rods
waiting on:
Comp Cams camshaft
going to get:
crank scraper
I picked up this very clean '76 Chrysler Cordoba this summer. Only 43,000 miles, 2nd owner car from Texas. Not a rich Corinthian leather interior it has the velour seats with the **** carpeting. I call it the Austin Powers model.
Nice car though, brings back memories from the "Bicentennial Era"
Oh great, now I will have Ricardo Montalban's voice in my head all day telling me the virtues of the "rich Corinthian leather" In 1976 my girlfriend wanted a Cordoba sooooooooooooo bad, I almost traded my 74 Cuda' in on one.
my other build is a 67 GMC shortbox...did frame off on it,,chassis is done,motor and trans installed, need wired,plumbed and primered and i can drive it...it has a 377 small block in it,full roller,dart heads,,,should be a ripper!!
my current build has me pretty far away from Oldsmobile for the next 2 or 3 months. i am building another 3 wheeler. here is a video of me cutting an almost new (about 20 hours) Honda TRX450 ER in half to build a new 3 wheeler.
http://www.youtube.com/watch?v=hFIox72_e78
this is what i will have after it is done.
I bought the Delta to be a daily driver, but lately, I've spent more time getting it together than I have on the reason I bought it...
My project car is a 2001 Mustang GT Bullitt.
The goal for it is to be 6-Speed and Vortech Supercharged. Right now, I've been cleaning and detailing. Finished a few little things on her, but essentially, right now, she's allowed to chill in the garage.
70 GTO Convertible - Getting close to the end after six years of work. I attached a pic of the frame with the drivetrain installed and a pic of the first fitting of the doors after paint. It's a bit further along now but I don't have any current pics on this computer - the doors are on, trunklid and wing are on, all the glass is in and the power windows are wired up, the top is on, exhaust is on, dynamat and carpet are in, etc.
Once I recover from the GTO, I'm going to tinker with my 67 Vista. It's a three seater wagon with 330 4v and factory AC. It's not much to look at, but I like it. In fact, I'm going to try to get it cranked up next week while I have some time off from work. I've had the original 330 soaking in Marvel Mystery Oil for a while now and it isn't frozen up so I'm hoping I can get it to fire up. The guy I got it from never had it running and he told me it had been sitting at the original owner's place for years. Anyway, somewhere down the road, I'm thinking of converting it to factory appearing bucket seat, 4 speed trans and console setup. I think that would be pretty cool.
I've got a '70 model Chevy C-10 pickup that I bought from an old friend earlier this year. It was his grandpa's truck, and we used to drive it around when we were 15-18 yrs old. I lost touch with him in the late '80's but found him again on facebook. To make a long story short, I ended up with the truck, which had sat since the early '90's. I brought it home, changed fluids, got it running, replaced the brakes and tires. I still need a fuel tank and a few other parts, but it's a driver/parts hauler for now. It will receive a frame off once I'm through with the Delta Custom project.
Me? i am deciding what the hell to do with my damn 95 caprice 9C1 with a lt1 and a t-56 transmission, carbon fiber driveshaft custom tri-y headers with a 2.5 inch exhaust. z-28 cluster gague, 4.10 gears with a limited slip, and the air intake to top it off. thinking about selling it but want to damn much for it, i need a gas saving car so i can spend more money to restore the current olds lol.
I guess I am as bad as the rest of you guys. lets see, current and ongoing projects:
1969 Camaro Rally Sport (for my oldest girl)
1965 Mustang Fastback (for my youngest girl)
1982 Eagle Bus being converted to a motor coach (so I can tell everyone to kiss off
and hit the road)
1970 Wesco 18' Flatbottom V-Drive boat
1970 Cutlass SX convertible (my car bought in 1982)
all these projects were so easy to finish in my head. hope I live to be 100 so maybe something gets finished.
and hit the road)
I just assembled and installed a new chevy 355 and a 5 speed overdrive and put it in a 34 Ford coupe. (Not mine, I'm always doing jobs for everyone else) Lots of access room to work with!
I wanted to take it out for a test drive but we got 18" of fresh powder yesterday.
