Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Speedometer Help electronic & mechanical
Old February 28th, 2011, 09:13 AM
Junior Member
Nailhead 88's Avatar
I was going to do a drive train swap LT1 & 4L60E with everything it takes to do it
Well that was until i found out you can't use a mechanical steel speedometer cable on a 4L60E no place to hook it up.
there is a $450 tail shaft kit but i'm not to interested in shelling out more money
bottom line have a working speedometer with the easiest fix
any thoughts scrap the idea go with an old style trans or maybe some of you have a better idea
i'm open to any ideas
update - well the reason i need the info was for a project drive train i was going to buy
but it was sold so no drive train no project - game over
Nailhead 88 is offline
Old February 28th, 2011, 07:38 PM
Aceshigh's Avatar
Find another. They're everywhere.
As to your question,
there's things like this if keeping your stock gauges is important to you.
http://www.abbott-tach.com/cablex.htm
Aceshigh is offline
Old March 1st, 2011, 05:19 AM
Junior Member
Thanks Aceshigh i'll check out that link
A stock gauge is now that important in this case
nklemens
June 4th, 2014 04:44 AM
Stevec
September 15th, 2012 10:41 AM
bigbrother
17
March 11th, 2012 06:45 PM
Holiday5488
May 5th, 2011 11:54 AM
Southern_Hospitality
November 23rd, 2009 05:51 AM
Quick Reply: Speedometer Help electronic & mechanical
