Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
questionbout 88 camaro
Old Jan 30, 2013 | 07:25 PM
rocket350's Avatar
1970 olds cutlass supreme
if i drive through a puddle, the steering will lock up andwill only turn a little bit.
it returns to normal after about a minute.
whatcan be causing the lockup
Old Jan 30, 2013 | 07:37 PM
lemoldsnut's Avatar
steering gear lock up
Is it in a puddle or just when it gets into a bind? Like hitting a bump or pot hole? Could be the control valve at the top of the steering gear. They have seals that seperate the ports in it. If they are worn it can flow to two directions at the same time. "locking up" There is a check valve in the back of the pump that could be weak too. But, more than likely is the gear valve. Meaning replace the gear.
Hope that helps
Larry
Old Jan 30, 2013 | 08:00 PM
rocket350's Avatar
Hope that helps
Larry
its only when i go through puddles
Old Jan 30, 2013 | 08:18 PM
Your power steering belt is loose.
Puddle splashes water onto belt.
Belt slips.
Steering gets tight.
If you do some serious barbell work, you'll stop noticing it when it happens.
Old Jan 30, 2013 | 08:27 PM
Rickman48's Avatar
Replace the belt.
Old Jan 30, 2013 | 09:42 PM
rocket350's Avatar
Originally Posted by Rickman48
Replace the belt.
ok ill look into replacing the belt, too lazy to do barbell work lol
TOONLOVESCHERYL
Feb 17, 2010 11:40 AM
Topless72
Mar 19, 2008 03:29 AM
tex70
Jan 27, 2007 08:31 PM
mjscutlass
Dec 26, 2006 07:12 PM
Winnipeg Cutlass
Apr 17, 2006 03:15 PM
