Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Pro Touring '72 now going LS2
Old May 12, 2016 | 08:28 AM
  #121
csouth's Avatar
Originally Posted by madmax442
Nice build! I can honestly say I wish you had an Olds engine in there but very nice overal!
Thanks. It would have an Olds motor it it wasn't for criminals... I couldnt see myself paying to build another BBO when i could buy an LS for 2/3 the cost with newer technology.
Old May 12, 2016 | 09:26 AM
  #122
madmax442's Avatar
That definitely sucks! Good luck with your new combo!
Old May 12, 2016 | 10:13 AM
  #123
wr1970's Avatar
Interesting build. How do police raid a garage not secure it properly and not be held accountable? Why didn't business insurance cover the losses? Gl with your build keep plugging away you will get it done.
Old May 12, 2016 | 01:42 PM
  #124
csouth's Avatar
Thanks, my goal is to be on the road this summer...
It wasn't a business, it was space my friend was sub-renting from someone else. It was a hobby building for him that was protected by his dog. Never had an incident before then. When the police raided they had animal control with them.
The police secured it the with what they thought was adequate means, but we found later they were supposed to call Balfour to secure the premises. There is an ongoing attempt to sue MSP and the City of Detroit, but I can't wait for a payoff that may not come....
Old Jun 4, 2016 | 08:01 PM
  #125
csouth's Avatar
Small victory today, finally spun the motor over. I had been dealing with some small wiring issues because I used the Ford solenoid with my trunk battery placement. Once I changed and wired the LS harness to get its constant power from the alternator vs the starter, everything was good. I'm going to button up the oil cooler and finish the fuel lines. I should be ready to attempt a true fire by the next wknd....
Old Jun 8, 2016 | 08:41 PM
  #126
DewChugr's Avatar
Photoshop God
I'm putting C6 brakes on mine, what are you using for a proportioning valve, booster/master?
Old Jun 9, 2016 | 12:58 PM
  #127
csouth's Avatar
I used all c5/6 for the booster and master. It did require some metric to standard conversion fittings for the prop valve. Prop valve is Wilwood Combo prop valve part #260-11179. Some have used the Tuff Stuff dual 9"...
You can check this link for a conversion recently completed. The part is listed there.
http://www.pro-touring.com/threads/1...brakes-booster
If you have anymore questions feel free to hit me up.
Old Jun 9, 2016 | 06:24 PM
  #128
csouth's Avatar
Looks like the guy i sent me ECM to did not flash it when he stripped my original harness as he said he would. Fired the car and it dies immediately. Everything I have read said it points to VATS not being disabled. After scanning I have a code P0141 which is bank 1 sensor 2 oxygen sensor. This also tells me it wasn't flashed because he was supposed to remove the after cat o2's. Not sure if I'm even going to deal with contacting him or send it to a reputable tuner that I've recently discussed a flash with.
Old Jul 3, 2016 | 09:44 PM
  #129
csouth's Avatar
Nothing really new right now. Waiting on my ECM to return after having it checked for VATS. Was told VATS is disabled so I need to see if something is killing my run after start. I also need to check fuel pressure. In the meantime I mounted my vertical billet bulkhead and started to mock up my Vintage Air hoses. I also moved the ECM inside to clean up the engine compartment a little.
I'll be an expert at installing this evaporator when its all done...lol
Old Jul 12, 2016 | 12:55 PM
  #130
csouth's Avatar
Got all the AC lines clocked and marked for crimping. Had to order special fittings from Cold Hose because the service fittings would not clear the inner fenders. These were known as their short drop 90 degree. Took the hoses to Pirtek on the way to work and had them crimped while I waited.
Old Jul 19, 2016 | 11:32 AM
  #131
csouth's Avatar
Took some downtime to cut and access panel in my trunk. Its already paid dividends since i had to move fuel lines around after having fuel in the tank.
I also make a small bracket to mount my clutch master reservoir. I didn't want to bolt it to the firewall, so i found a convenient spot next to the brake booster. I'll paint it when the car is truly finished after paint.
Old Jul 19, 2016 | 03:17 PM
  #132
Awesome access point, very clean.
Old Jul 21, 2016 | 07:03 AM
  #133
csouth's Avatar
Thanks. I paid more for the kit than I would have liked, but it gives it the finished look i was hoping for.
Old Jul 22, 2016 | 05:56 PM
  #134
OldSoldier's Avatar
Car Nerd
Chris,
I really like the fuel tank access hatch. I have had my fuel tank in and out on my Chevelle a few times lately and that would have really come in handy. I may borrow that idea on the Olds.
Old Jul 22, 2016 | 09:05 PM
  #135
csouth's Avatar
Originally Posted by OldSoldier
Chris,
Go right ahead. I got mine from Summit, bolts are not included though.
Old Nov 9, 2016 | 01:33 PM
  #136
csouth's Avatar
Looks like I haven't been here in quite some time. So the one thing I realized is I would never really want to wire a car again...lol
I did get my Vintage Air mostly wrapped up with the wiring. I'm going to add a ground and "key on" distribution block to help some of the routing. I'm also getting an adapter plate for a Detroit Speed wiper kit i was given. The kit is for a 68, which mounted differently. A buddy from the Pro-Touring forum is making one for me to use this kit on the 72. I also fitted the DSE switch in the stock location. Since the adapter plate for the wiper switch is made for a Chevelle with side to side slide, I had to modify mine. If I could use the original **** it wouldn't be much different.
Old Nov 10, 2016 | 05:34 AM
  #137
RetroRanger's Avatar
72 Olds CS
I like how clean the AC n heater hoses are. Is that firewall connected part of the VA setup or a special order unit.?
Old Nov 10, 2016 | 05:56 AM
  #138
csouth's Avatar
That is their billet firewall bulkhead. If you order a kit from them, you have to get what they call their modified hose kit to go with them. The stock kit uses a method when the hoses pass through the firewall to the evap under the dash. When you get the firewall bulkhead, there are -AN connections on both sides. It can be a little bit of a pain manipulating the fittings because the evap is not intended to be so close to the incoming hose.
It's a very nice kit. i think my issues were just because I'm mixing parts, ls2, smoothed firewall, etc... No way it was going to be a smooth install.
Old Feb 16, 2017 | 11:09 AM
  #139
csouth's Avatar
Just switching gears a little to my seats. I finished up my Vintage Air, but I'm not ready to install my dash yet as there are a cpl more things in want to finish under there. I decided to move to getting my interior ready. I welded elevator bolts to my floor pan to use as studs for my Recaro seat brackets. My intention was to use my friends rear bench as a temporary setup until i could have my rear bucket setup installed. My intent was to use my friends old rear bench, but a '68 Chevelle rear seat is wider due to the armrest configuration. I ended up starting on my plan for the rear seats sooner than i expected. I also took the time to trim and install my rear carpet.
With some advice from by buddy that does interiors, I built this base for the new rear seat. Here is one of the rear seats as it will sit before my friend completes the upholstery. He will build filler between the seats and and both sides when he does the upholstery.
Here's the base installed with one seat is it will be when finished.
Old Apr 24, 2017 | 11:53 AM
  #140
csouth's Avatar
Nothing major to add, just finishing up detail work.
Finally put the car back on the ground after swapping out my eBay lowers to SPC. Adjusted the ride height to where i wanted to be. Trans crossmember is about 5.5" from the ground, from what I have read this enough clearance.
Purchased my insurance and plate as motivation to push me over the finish line in the coming months.
Old Apr 24, 2017 | 03:58 PM
  #141
gearheads78's Avatar
car guy
Car has come a long way! Looking great man! Love the bronze color on the wheels.
Old Apr 24, 2017 | 04:21 PM
  #142
csouth's Avatar
Thanks! Your Cutlass was an inspiration when you built it back then. I remember seeing it at GG Columbus when you finished.
When I ordered them in '12 Jason Rushforth thought the bronze was a great idea because no one was doing that color on muscle cars, especially without a polished lip. The craze back then was "murdered out" all black or something charcoal. The car has taken so long I'm behind the curve now.
Old Apr 24, 2017 | 04:26 PM
  #143
Its coming along nicely, don't worry about the time constraints.
Old Apr 24, 2017 | 04:44 PM
  #144
car guy
If you wait long enough trends repeat
I tried to buy mine back a year ago when it was for sale but could not come up with the funds. I'm hopping its still in his garage and on day I can "make that call"
Old Apr 24, 2017 | 07:04 PM
  #145
csouth's Avatar
Thanks for the words of encouragement. It's been a long bumpy journey, but I can finally see light!...lol
That's what they say. Heck bell bottoms were back in style again for a little while...lol
You're buyer knows what he has, that car will be around I'm sure.
Old Apr 24, 2017 | 07:57 PM
  #146
Paladin31's Avatar
Chris great job on this, what a vision to put it all together, and with very nice & crisp execution.
Kudos
Brett
Old Apr 25, 2017 | 08:11 AM
  #147
csouth's Avatar
Kudos
Brett
Thanks for the kind words. Looking to finish this soon, cruisin' weather is right around the corner.....
Old Apr 25, 2017 | 08:29 AM
  #148
car guy
Last time I talked to him it had been sitting in his garage over 2 years without even being started.
Old Apr 26, 2017 | 08:12 PM
  #149
csouth's Avatar
That's not good at all... Is he one of those car hoarders? The kind to have cars and won't sell so no one else has it?
Old Apr 27, 2017 | 05:02 PM
  #150
Alex72cutty's Avatar
Very Nice
Old Apr 27, 2017 | 05:41 PM
  #151
83hurstguy's Avatar
Car looks tough, wheels are nice. Keep up the good work!
Old Apr 28, 2017 | 10:25 AM
  #152
csouth's Avatar
Originally Posted by Alex72cutty
Very Nice
Thanks.... Once I'm done fooling around, the center caps will go back on.
Should have my gauges and steering wheel installed tonight....
Old Sep 25, 2017 | 10:10 AM
  #153
csouth's Avatar
No updates here in a while.... I changed out my engine management from stock GM to Holley HP EFI. I was having couple of tuning issues that were stopping me from getting the engine to run as it should.
I also added a couple of performance upgrades because I got them for a song. Ported FAST 102. Got the intake for $500 from a guy going to a Supercharger. The TB i bought new. I sold My intake for a net cost of $300! The throttle body was necessary after my switch to DBC.
Old Sep 25, 2017 | 10:27 AM
  #154
csouth's Avatar
Finally installed my gauge cluster along with my steering wheel and console.
Old Sep 25, 2017 | 07:12 PM
  #155
deejai35's Avatar
Looking good. Power Tour is 9 months away. Good Guys Columbus is 10 months away. Keep the progress going. I told my dad I was disappointed in my current power output and now he is trying to get me to go LQ4. ��
Old Sep 25, 2017 | 08:43 PM
  #156
csouth's Avatar
You can get those pretty cheap right now, but the mileage will be high. I personally like the LY6....
Old Oct 14, 2017 | 06:27 AM
  #157
deejai35's Avatar
I see LY6 has better flowing heads. Any other reason? I am still learning about all the engines in the LS family. I would really like to find a 5.7L just so my car can still have a 350 cubic inch motor.
Old Oct 14, 2017 | 07:23 AM
  #158
csouth's Avatar
I like the LY6 because if you ever chasing more HP, its the option is already there. I'll use my LS2 for example, I have a stock motor that I purchased a cam to swap in, if I don't feel its enough I will need to port my heads or do forced induction.
CNC porting my heads would cost 1k+. LY6 already has high flowing heads, so a cam swap would put you in a great spot. If I want to get supercharger the cheapest being OEM style, I would need to change my heads to the ones already on the LY6 because the charger is for rectangle port heads which the LY6 has.
Not to say that you want to build this 500hp motor, but the LY6 has a best base to start with IMO.
Old Oct 14, 2017 | 05:13 PM
  #159
deejai35's Avatar
Good to know. I think it is time to move on from the small block I have. I am debating Olds 455 or LS motor. So much potential in the modern engine and so much upside. Especially considering that my car should be an all purpose vehicle.
Old Oct 14, 2017 | 08:51 PM
  #160
csouth's Avatar
Unless you're just dying to keep it Olds, I'd do the LS.
