LS cutlass
Whew, glad this is in the non-Olds section.
Only crazy people would put an LS in an Olds ;-)
How about more details? Trans? Looks like a Sanden, did you go with VA?
Anything else??????
Anything else??????
upgrades
Ls engine swap change the rear end to posi 3.42 grears elec cut out (for fun) front and rear disc brakes (SSBC) front and back QA coil over shocks HOTCHKIS FRONT END KIT AND REAR KIT DROP 2" SPRING CUSTOM GAUGES NEW FUEL TANK WITH INTANK FUEL PUMP.
Ls swap
2. I used after market lokar throttle cable and yes i used the stock peddle.
3. The computer is mounted under the dash.
