Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
JOZW30's 55 88 LS2 build
Old Feb 24, 2016 | 07:43 PM
  #241
jozw30's Avatar
Quick update. Got the front brake and fuel lines hooked up and tightened down. Need a couple grommets for the bulkhead I made for the lines passing through the firewall.
File Type: jpeg
Old Feb 24, 2016 | 07:47 PM
  #242
jozw30's Avatar
Lokar trans dipstick. Need to get the trans cooler lines bent up next and hopefully start wiring soon.
File Type: jpeg
Old Mar 7, 2016 | 05:25 AM
  #243
jozw30's Avatar
Those GM push in connections for the trans cooler lines really proved problematic. I found adapters that work for the trans side, but not the cheap Camaro radiator I have all fit up.....
I am switching to an aftermarket aluminum version which has welded in fitting ports. Spent a bunch of time and money trying to get these lines to work....frustrating.
Anyway, got the power steering hoses figured out. The rack is from an 86 Ford Thunderbird, and the t-bird hoses will work. The pressure hose just needs to be cut really short and I will get a -6an fitting crimped on. Had to install a flow regulating fitting into the Corvette pump to get to the Ford 2gpm flow rate.
File Type: jpeg
Old Mar 7, 2016 | 05:26 AM
  #244
jozw30's Avatar
Also started some wiring!
File Type: jpeg
Old Mar 7, 2016 | 05:28 AM
  #245
jozw30's Avatar
Got the fuse block mounted and even installed the ignition switch.
File Type: jpeg
Old Mar 20, 2016 | 07:34 PM
  #246
jozw30's Avatar
Power steering buttoned up
File Type: jpeg
Old Mar 20, 2016 | 07:38 PM
  #247
jozw30's Avatar
Installed the Specialty Power Windows mechanical wiper system to replace the old vacuum stuff. Zip ties used to make sure the park position is right...
Old Mar 20, 2016 | 07:39 PM
  #248
jozw30's Avatar
Adapted the original *****.....
File Type: jpeg
Old Mar 20, 2016 | 07:45 PM
  #249
jozw30's Avatar
Fabbed up a trunk mounted battery tray and ran the 1/0 gauge + and - cables all the way up front. I also got the other grounds hooked up.
Hoping to get this thing fired up late April maybe?
File Type: jpeg
Old Mar 20, 2016 | 07:50 PM
  #250
jozw30's Avatar
Main wires from battery.
File Type: jpeg
Old Mar 21, 2016 | 09:44 AM
  #251
Olds Dad's Avatar
Collector of Stray 55's
Hope to see a video of the first 'fire up' - although the zip tie wipers will be hard to beat!
Old Apr 3, 2016 | 08:14 PM
  #252
jozw30's Avatar
Not a lot to show but I have been spending a lot of time wiring. I've got the two speed fan controller all sorted out with the two temp signals from the PCM and the trinary switch on the AC.
Got the main engine harness in place and the computers and engine fuse panels mounted to the left inner fender.
I installed a remote trans oil cooler on the back of the right front inner fender. Nice unit from Derale. Has a thermostatically controlled fan.
I started the ignition circuit today. This was more complicated than I thought it would be. Without a neutral safety switch on the column or shifter, I had to tap into the PNP (PRNDL) switch on the 4L60E for a park/neutral signal to a relay in the start circuit. I also grabbed the 12v output signal in that switch for the back up lights.
I also installed a 1999 Camaro brake switch to get the second switch for torque converter control, and bench bled and installed the under dash brake master cylinder.
Trying to make the wiring as professional looking as possible so I'm taking my time on this part.
File Type: jpeg
Old Apr 18, 2016 | 08:24 PM
  #253
jozw30's Avatar
Still working on the wiring. It's coming along pretty good. Got the ignition circuit complete and it cranks over. Spent this past weekend getting the tank assembled, wired, and plumbed. All that's left on the fuel system is a section of 2" fuel hose for the filler neck connection.
I reworked the coil pack and injector harnesses for the remote mounted coil packs. Came out petty clean.
I also dusted off the pretty Fuaxmobile valve covers and got them installed. It's starting to look like a real car.....
Also started checking out the local upholstery shops for the interior.
Some pics:
File Type: jpeg
Old Apr 18, 2016 | 08:26 PM
  #254
jozw30's Avatar
Coil pack harness before:
File Type: jpeg
Old Apr 18, 2016 | 08:27 PM
  #255
jozw30's Avatar
After:
File Type: jpeg
Old Apr 18, 2016 | 08:29 PM
  #256
jozw30's Avatar
Current shot of engine:
File Type: jpeg
Old Apr 19, 2016 | 05:58 PM
  #257
jgodbolt's Avatar
Looks great!
Old May 16, 2016 | 01:26 PM
  #258
jozw30's Avatar
Lots of work since the last update. The exhaust is done. 2 1/2" with dynomax ultra-flow welded mufflers. Even managed to fit an "H" pipe in there.
Can't wait to hear it rumble.
I also have the AC system buttoned up. All that's left is to hook up the controls which are in the console.
Radiator hoses, drive belt are in.
This weekend, I installed the custom driveshaft and set the pinion angle by tacking the spring perches in place. After I get the car running, I will pull the rear end, finish the welds and get the housing powder coated. Then final assembly on the drivetrain
Maybe try to start it up this coming weekend!
Getting nervous.....
File Type: jpeg
Old May 16, 2016 | 01:28 PM
  #259
jozw30's Avatar
Current shot of engine bay....
File Type: jpeg
Old May 27, 2016 | 07:16 AM
  #260
jozw30's Avatar
For those still hanging in there with me....
Old May 27, 2016 | 07:21 AM
  #261
jozw30's Avatar
Cold air intake set up.
File Type: jpeg
Old May 27, 2016 | 08:12 AM
  #262
csouth's Avatar
The engine bay is beautiful! Where'd you get the silicone piping for your intake?
Old May 27, 2016 | 09:34 AM
  #263
jozw30's Avatar
http://www.intakehoses.com/
Great guy. Helped with my layout to make sure I ordered the right pieces.
Old May 27, 2016 | 11:16 AM
  #264
csouth's Avatar
Thanks... Hopefully I can figure a solution for my situation from here.
Old Jul 18, 2016 | 05:41 AM
  #265
jozw30's Avatar
Not lot new to report, but I have been working hard. Brakes have been giving me fits. Can't seem to get the flares sealed on a few lines. Have remade several. Think it's finally tight.
Didn't like how the de-arced leaf springs looked after getting the weight on the car, so I ordered new stock springs and will use lowering blocks. Got one side done this weekend.
I also got my power window and door lock stuff. Have been busy installing the window run channel and sweeps. Wish these cars were popular enough to get these parts pre-bent.....
Once I get the rear end re-assembled, I should be ready to put it in gear for the first time. Assuming the brakes are in working order.
File Type: jpeg
Old Jul 18, 2016 | 05:45 AM
  #266
jozw30's Avatar
Back seat frame.
File Type: jpeg
Old Jul 18, 2016 | 05:47 AM
  #267
jozw30's Avatar
Toro seat all hooked and bolted in place. I also drilled the rear seat belt mounting holes.
File Type: jpeg
Old Jul 18, 2016 | 05:50 AM
  #268
jozw30's Avatar
Put the rear wheels on for the first time since the car was painted....
File Type: jpeg
Old Jul 18, 2016 | 06:17 AM
  #269
Tedd Thompson's Avatar
looking good and still following your progress, you do amazing work.... Tedd
Old Jul 18, 2016 | 08:15 AM
  #270
jozw30's Avatar
Thanks Tedd,
I feel like I'm so close, but there is still a ton to do. I'm trying to get it to the upholstery shop in the next month or so, but if these ankle biter issues keep hitting me, I don't know.
I can't wait to just drive it up and down the street for the first time....who's knows the last time this car actually moved under its own power.
Old Jul 22, 2016 | 06:20 PM
  #271
jozw30's Avatar
Working on the glass run channels, fuzzies and side glass install (what a pain).....
The NU-RELICS power window kit went in perfect!
File Type: jpeg
Old Jul 22, 2016 | 06:24 PM
  #272
jozw30's Avatar
Power windows....
Old Jul 23, 2016 | 07:59 AM
  #273
OldSoldier's Avatar
Car Nerd
That sure is pretty! I love it. How many miles a week will you be putting on it?
Old Jul 23, 2016 | 03:21 PM
  #274
jozw30's Avatar
Thanks OldSoldier! My goal was to a have a great driving reliable car so that we would use it a lot.
Wouldn't call it a daily driver, but my hope is that it's not like my W30 which sees the light of day three or four times a month September through May.
Joe
Old Jul 27, 2016 | 07:49 PM
  #275
gearheads78's Avatar
car guy
Stainless lines? Snug then back off, and repeat 3-4 times tightening a little more each time. It was the only way I could get stainless lines to seal.
Old Jul 28, 2016 | 05:29 AM
  #276
jozw30's Avatar
No stainless, just found another thing I am apparently not that good at....
All buttoned up now. If I can ever get the rear caliper parking brake mechanisms adjusted, I may be able to put this thing into gear for the first time!
Baby steps.
Old Aug 7, 2016 | 06:02 PM
  #277
SnakeBit's Avatar
Car Whisperer
Really nice job!!!!!!!!!!!!!!!!!
Old Aug 8, 2016 | 08:10 AM
  #278
oldsguybry's Avatar
NOVICE car nut
Man , all you guys are making me jealous . Great job !
Old Sep 11, 2016 | 06:11 AM
  #279
jozw30's Avatar
Well, this thing moved under its own power for the first time in probably 30+ years.....
I'm having trouble with the transmission pushing fluid out of the vent tube, but it ran great and the suspension, brakes, and steering felt really balanced considering all of the mismatched parts I've put together here.
I took it easy, but I probably drove it a half mile.
Once I get the trans figured out, it's off to the interior shop.
Sorry for the bad video, just lucky the wife heard me take off and came back to capture some portion of the cars maiden voyage. I was too excited/nervous to think about a video.......
Old Sep 11, 2016 | 06:36 AM
  #280
tru-blue 442's Avatar
Old School Olds
Wow, that thing defies gravity and sounds great too!
I will enjoy the pics when you get it finished up, nice job Joe.
