Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
JOZW30's 55 88 LS2 build
Old Dec 13, 2014 | 09:27 PM
  #121
oldzzy's Avatar
wait.... what....
Very nice!
Old Dec 17, 2014 | 01:53 PM
  #122
Blase's Avatar
Nice. Doesn't moving the coil packs to the back of the motor have any affect on the performance? Long wires and all?
Looks very nice. I'm hoping to do something similar one day!
Old Dec 17, 2014 | 06:01 PM
  #123
jozw30's Avatar
Thanks! Lots of coil relocation kits out there, haven't heard of any issues with the longer wires. Even heard of guys running the wires through the firewall with the coil pack inside under the dash.
I guess I'll find out.
Old Dec 17, 2014 | 07:23 PM
  #124
Olds Dad's Avatar
Collector of Stray 55's
You, sir, are a man among men
Love the 303-style valve covers
Old Dec 18, 2014 | 03:39 AM
  #125
jozw30's Avatar
Thanks Gordon! I was not so much trying to make the motor look like an Olds motor as I thought it more of a subtle tribute. Not going to put the rocket decal on it.
Hope you and your family have a Happy Holiday Season!
That goes for everyone here!
Joe
Old Dec 26, 2014 | 01:01 PM
  #126
jozw30's Avatar
Finished welding up the seat mounts and installed a set of Julianos three-point seat belts. Worked out a lot better than I thought. Having a "B" pillar helps......
I'll wait to install the rear belts until I figure out what the rear seat will be.
Old Dec 26, 2014 | 01:03 PM
  #127
jozw30's Avatar
Spacer for the retractor. There is a reinforcing plate inside the inner panel.
Old Dec 26, 2014 | 01:06 PM
  #128
jozw30's Avatar
Retractor installed.
Old Dec 26, 2014 | 01:10 PM
  #129
jozw30's Avatar
Lap belt mounting point (through floor brace).
Old Dec 26, 2014 | 02:33 PM
  #130
Eddie Hansen's Avatar
Awesome work joe, love the firewall work! Just amazing
Old Jan 2, 2015 | 04:46 PM
  #131
jozw30's Avatar
Hung the fenders and modified the a-arm openings to fit better with the new front chassis parts. Also made a change to the coil pack location and wire routing. I think this looks pretty cool. Kinda breaks up the big smooth firewall a bit.
Still need to find the right wire holders.
Old Jan 2, 2015 | 04:48 PM
  #132
jozw30's Avatar
Inner fender marked up.
Old Jan 2, 2015 | 04:49 PM
  #133
jozw30's Avatar
Cut and test fit
Old Jan 2, 2015 | 04:50 PM
  #134
jozw30's Avatar
New shape welded in place.
Old Jan 2, 2015 | 04:53 PM
  #135
jozw30's Avatar
Coil packs moved to firewall.
Old Jan 2, 2015 | 04:55 PM
  #136
jozw30's Avatar
One more....
Happy New Year everyone!
Old Jan 2, 2015 | 06:14 PM
  #137
Looks awesome
Old Jan 3, 2015 | 03:49 AM
  #138
a58strod's Avatar
Looking good!
Old Jan 3, 2015 | 02:10 PM
  #139
gearheads78's Avatar
car guy
Looking better and better.
Old Mar 8, 2015 | 07:34 AM
  #140
jozw30's Avatar
Been a while since last update, but I've been busy with a lot of little stuff. Built a console and welded in mounting tabs, got the shifter cable working, spent a bunch of time on the motorized door in the dash (almost done....), finally installed the front sway bar, installed the Holley accessory drive kit as well.
I also got the Old Air Products AC system mocked up, I just need to cut the giant holes in the dash for the vents
I will be taking the car to the body shop either next Sunday or the weekend after that. It's really up to me button up the last few mods. He's waiting for me so I have to get busy.
Pretty stoked to get to this step. Supposedly he will finish in 4-5 months. He does seem to move along pretty good on the projects I've seen at his shop.
Old Mar 8, 2015 | 07:35 AM
  #141
jozw30's Avatar
Accessory drive brackets. These Holley pieces are really nice and you can't beat the cost vs other LS drive kits.
Old Mar 8, 2015 | 07:38 AM
  #142
jozw30's Avatar
I decided to run the AC/heater hoses out the side of the cowl instead of through the firewall. Boxed in a bulkhead to hole the grommets.
Old Mar 8, 2015 | 07:40 AM
  #143
jozw30's Avatar
Built brackets for the condenser and drier. Worked out nice.
Old Mar 8, 2015 | 09:30 AM
  #144
Don R.'s Avatar
Very impressive, lots of good solutions.
Old Mar 15, 2015 | 07:43 PM
  #145
jozw30's Avatar
Ran the lines to the under dash brake unit. Holy cow, that was a lot of bends! I just need to make a cover to with some grommets.
Came out pretty good though. All of the lines are done but one section of fuel line that I will finish during final assembly (I plan to get some billet fuel rails so I'll wait for those).
Old Mar 15, 2015 | 07:46 PM
  #146
jozw30's Avatar
Through the firewall.....
Old Mar 15, 2015 | 07:54 PM
  #147
jozw30's Avatar
Am using Old Air Products Hurricane AC system and got everything mocked up but really didn't like the chrome vents sitting on top of the curved dash surface so I recessed them. This was way more work than I thought it was going to be, but they came out great!
They're all metal too.
Made from a piece of exhaust pipe.
I'll be using a dual center vent in the upper part of the console.
Old Mar 15, 2015 | 07:56 PM
  #148
jozw30's Avatar
Tubes capped off.
Old Mar 15, 2015 | 07:57 PM
  #149
jozw30's Avatar
Holes cut for vents....
Old Mar 15, 2015 | 08:00 PM
  #150
jozw30's Avatar
Holes cut into dash (the scary part &#128561....
Old Mar 15, 2015 | 08:03 PM
  #151
jozw30's Avatar
Test fit and trimmed
Old Mar 15, 2015 | 08:05 PM
  #152
jozw30's Avatar
Welded up solid
Old Mar 15, 2015 | 08:08 PM
  #153
jozw30's Avatar
Finish ground with nice radius.
Old Mar 15, 2015 | 08:11 PM
  #154
jozw30's Avatar
Primered with vent installed. Shouldn't need much filler at all.
Old Mar 15, 2015 | 08:15 PM
  #155
jozw30's Avatar
Looks like the car is going to the body shop next weekend! I have a few odds and ends to finish up this week, but it's pretty much ready now.
Can't wait to be sending update pictures of the bodywork being done!
Old Mar 16, 2015 | 07:03 AM
  #156
car guy
Nice work on the vents. So I assume you are going to run a bulkhead through the firewall brake lines?
Old Mar 16, 2015 | 09:13 AM
  #157
Don R.'s Avatar
I probably missed it but how did you do the 90 degree connection from the pedal to the booster?
Old Mar 16, 2015 | 09:45 AM
  #158
jozw30's Avatar
Don,
Couple different companies sell the set-up. I used the rig from Scott's Hot Rods.
You have to reinforce the firewall on most cars to take the pedal load.
Joe
Old Mar 16, 2015 | 09:51 AM
  #159
jozw30's Avatar
gearheads78, thanks!
For the brake lines I plan to make a thicker trim plate with grommets that will screw down onto the firewall to clean everything up.
Joe
Old Mar 17, 2015 | 02:36 PM
  #160
car guy
Joe
Joe I highly suggest using bulk head connections through the firewall. Its just a better design and service down the road would be much easier. Your doing a great job on everything and really putting a fire under me to get my other stuff out of the way so I can work on mine.
Lots out there but here is a sample
http://www.speedwaymotors.com/Steel-...ter,31848.html
