Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
'72 Cutlass LS2/6L80E build
Old Dec 31, 2013 | 06:54 AM
  #41
70cutlass831guy's Avatar
Originally Posted by Aceshigh
Do you mean a driveshaft ??
Mine will be a custom made one. Stock just wouldn't be able to handle it.
Old, decaying rubber inside the sleeve, etc etc.....ticking time bomb.
Yah thats what I meant. Drive Shaft. I was thinking about maybe doing a 5.3 cruiser. So a stock drive shaft would be fine for my application. I was wondering if it would work with a 4l60.
If i did do the swap it would have to be super on a budget.
I would love a dailly driver.
Old Dec 31, 2013 | 06:57 AM
  #42
Originally Posted by chocolate apocalypse
Aces is right, I had a custom made driveshaft from Denny's Driveshaft whipped up for my car. You may be able to get away with it if you keep the engine completely stock but you still may have to change the yoke depending on if you use a 4l60 or 80 and/or shorten the driveshaft depending on trans choice and motor placement. Might as well spend the extra dough on a new one, especially if you plan on power upgrades.
Thanks for the info. I plan on complete stock for now. I will getting everythng together first Before I do anything.
Old Dec 31, 2013 | 07:14 AM
  #43
chocolate apocalypse's Avatar
I've read going from a turbo 350 to a 4l60 you'll have to shorten the driveshaft approx 3". Slip yokes have the same diameter and spline count so the stock one should work. So shorten the stock driveshaft, throw in some new u-joints to be on the safe side and you should be good to go.
Old Dec 31, 2013 | 06:54 PM
  #44
Aceshigh's Avatar
Yes, I paid $97 to have this done back in 2004 for my TH350 to 700R4 conversion in my Camaro.
That one was an all steel driveshaft though.....
These Olds driveshafts have a rubber insulated sleeve driveshaft and aren't worth bothering with
according to the driveshaft shops. If you look at this pic, you can see the shaft shrinks down in diameter
towards the left end.....thats the smaller end slid into the bigger end with some kind of rubber insulator.
I was told not to reuse mine.
Old Jan 2, 2014 | 01:11 PM
  #45
Ill do that . Thanks for info.
Old Jan 2, 2014 | 01:18 PM
  #46
[/QUOTE]
Good info. Where would you suggest I look for a new drive shaft? Not high dollar. for a daily driver?
Old Jan 2, 2014 | 01:56 PM
  #47
Those old sleeved drive shafts are prone to the rubber disintegrating and developing vibrations. A new steel drive shaft are not that expensive and most large metro areas have places that make one up for you. I think mine was around $250 with u joints.
Old Jan 2, 2014 | 02:04 PM
  #48
[QUOTE=oldcutlass;635589]Those old sleeved drive shafts are prone to the rubber disintegrating and developing vibrations. A new steel drive shaft are not that expensive and most large metro areas have places that make one up for you. I think mine was around $250 with u joints.[/QUOTE
Not bad. I have to find a driveshaft shop.
how about the oil pan on the 5.3 will the steering hit on oil pan? Ive read a caddy CTSV pan will clear.
Old Jan 3, 2014 | 12:51 PM
  #49
csouth's Avatar
[QUOTE=70cutlass831guy;635593]
You can use a CTSV pan or F Body pan. Interference will depend on a number of things, adapter plates, motor mounts, frame mount position.
Old Jan 3, 2014 | 04:42 PM
  #50
[QUOTE=csouth;636100]
Old Jan 3, 2014 | 05:42 PM
  #51
2X72's Avatar
shaft
check out these guys for a shaft. They sell steel and aluminum in 1/2 increments. Pretty reasonably priced. I bought mine through them.
I am doing something quite similar with my 71.
http://www.colemanracing.com/Drivesh...350-P3853.aspx
Old Jan 3, 2014 | 08:40 PM
  #52
Whats with this statement at the bottom of the ad??
These driveshafts offer an 8-lb. weight savings over standard steel shafts and are rebuildable. WARNING: These driveshafts are not for street use or drag racing.
csouth
Non-Olds Engines
222
Jan 5, 2025 10:52 AM
jozw30
Non-Olds Engines
353
Jan 23, 2018 01:02 PM
csouth
Sep 1, 2015 04:19 PM
pcard
Non-Olds Engines
38
Mar 18, 2012 06:50 PM
