Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
1970 Olds 442 clone gets Gen IV 6.0L & 6 speed transmission
Old Jun 1, 2011 | 04:46 PM
  #41
Aceshigh's Avatar
Originally Posted by garys 68
Hey, while you have the engine out and front end in pieces.......
Just about everyone has interference between the inner tie rods ends and the oil pan. It's worse with the grease fittings that stick inward.
If you put a 1/4 fine thread allen plug in the grease fitting holes, then drill and tap the back or bottom of the end for new grease fittings, you'll eliminate a lot of that issue.
Thanks for the heads up.
I'll have to take a closer look into this. I thought that's why you made
your 1/4" spacers in between the new mounts and motor plates??
So even after those spacers there's STILL an issue with the tie rods??
I have to rip apart the front end to send all my metal in for sandblasting
and powdercoating.
There's a few bolts I was having a hard time getting to at the moment to
release the front top metal piece (not the rad cover)
Originally Posted by Oldsguy
Aces,
That bare block with the heads and intake looks so cool. Interested in seeing the engine with all the stuff on the front/top of it. I think almost ALL V8s look so cool but they loose some of their 'muscle' image when they get all the stuff on them. I like to see the block, heads, headers, etc. The newer engines with EFI seem to suffer the most with all the stuff on the upper intake.
Looks awesome all cleaned up like a regular V8 right??
I do agree with you, it does lose some of the classic muscle car engine look
outside of the engine bay. However, INSIDE the engine bay it you don't see
much of the front engine anyways.
This is what the end product will look like in the engine bay.
Old Jun 1, 2011 | 05:23 PM
  #42
garys 68's Avatar
Since the engine is slightly offset, the tie rod clears in one direction, but barely hits the pan on the other side. That's without the grease fittings in their original location.
It's a 15 minute fix with everything out, so do it now.
Old Jun 1, 2011 | 11:56 PM
  #43
UnkleMarc455's Avatar
GM's Best Division
@Gary 68, do you have any pics of this fix looks like i'm headed down this road also and i've already got my motor out. Might as well get prepared for it now since im cleaning up the engine bay first.
Old Jun 2, 2011 | 02:04 AM
  #44
garys 68's Avatar
Since I only discovered the issue after everything was together, I only have the allen plugs in now.
Old Jun 2, 2011 | 08:16 PM
  #45
Kidcutty's Avatar
Easy Does It!
re
and powdercoating.
Aces,
what do you think of the lq9?if you could have gotten either for the same price,which one would you have chosen and why?Dont be biased.
Old Jun 3, 2011 | 07:12 PM
  #46
Aceshigh's Avatar
Originally Posted by Kidcutty
Aces,
I can see this will go in circles , so I'll answer it like this.
The Gen III 5.3L , and 6.0L LQ4 and LQ9 are all good motors.
End goal and budget is what you have to go by to decide which to buy.
My goal and budget is my own, so I chose a newer Gen IV engine.
I already own a Gen III LS1. I would prefer an LS9 with 638hp SC'd.
However, my budget doesn't allow for a $22,000 barebones engine.
Choose what you can afford, and that meets your desired end goal.
My goal is to twin turbo my 442 eventually......so I wanted the best
heads I could buy for head flow #'s. (see comparison below)
A 600-700hp 6 speed pro-touring DD cruiser that gets over 22-25mpg
highway is my goal. Somewhat of an impossible feat with classic engines.
Read.
http://en.wikipedia.org/wiki/GM_Vort...neration_III_2
LQ9 = 345hp and heads flow (Source)
Here's the stock 317 port:
Lift......Int...........Exh
.100" ..64.8........53.3
.200"..142.1.......111.6
.300"..204.3.......146.8
.400"..233.5.......164.9
.500"..250.0.......174.2
.550"..251.2.......181.2
.600"..253.0.......184.4
LY6 = 385hp and heads flow (Source)
Here's the stock L92 port
4.030” test bore
Lift ___.100 _.150_.200_.250_.300 _.350 _.400 _.450 _.500 _.550 _.600 _.650_.700_.750
#1 Int. 74.9 109.4 154.4 193.5 225.3 252.8 274.6 292.7 308.8 321.0 328.7 326.6 310.0 316.6
#1 Exh. 63.6 97.9 126.1 148.7 162.3 178.6 189.6 197.6 205.5 210.7 214.6 217.8 221.2 223.5
Old Jun 3, 2011 | 07:55 PM
  #47
OLD SKL 69's Avatar
GM Enthusiast
Looks great so far Aces. Keep the pics coming!
BTW, I know what you mean about the versatility of todays LS engines. I was thumping out over 400 at the rear wheels of my 01 Z28.. It was an absolute blast to drive. Scared the crap out of my wife when I floored it!
Old Jun 4, 2011 | 05:50 AM
  #48
f-85's Avatar
LAME!!!!! This should be in NON olds powered section!!!!!
Old Jun 6, 2011 | 10:32 PM
  #49
GM's Best Division
Well, can't please them all but keep the updates rolling in, i check LS1tech.com for A-body swaps also but i'm mostly viewing CO. Any GM Muscle car remake would be getting an LS3 or better, LAME could be reading 47 post of something you don't like! Lets respect an owners decision to do what he wants with his car!
Old Jun 7, 2011 | 05:13 AM
  #50
f-85's Avatar
Is anybody gonna move this thread?
Old Jun 7, 2011 | 01:08 PM
  #51
Aceshigh's Avatar
Good resource for info.
I do agree, almost any modern GM muscle car would be LSX powered.
I'm stuck figuring out my motor mounts right now, then I'll post pics.
Thanks.
Just power washed my engine bay, and painting it in the meantime.
Core support is getting yanked next for SB and Powdercoating.
Old Jun 18, 2011 | 11:15 AM
  #52
Aceshigh's Avatar
All cleaned and ready for the new implant.
Radiator support, hinges, and cover getting blasted and PC'd as we speak.
Gotta reroute a new brake line for the crossover.
Old Jun 19, 2011 | 06:56 AM
  #53
garys 68's Avatar
Looks great. I wish I had done mine during warmer weather so I could have cleaned up and painted the engine compartment better.
Old Jun 19, 2011 | 12:42 PM
  #54
Aceshigh's Avatar
Give's true meaning to the term "Gutless Cutlass".
I wish I'd have done this much on my Camaro's LSX install.
I still gotta rip out the booster, master and prop valve.
Rerouting all new lines I think.....
Gary, on the drivers side SBC motor mount, only 2 holes line up
with existing holes. Did you have to drill out a 3rd hole ??
I'm assuming I won't get all 4 holes lined up due to the way these
sit on the K-member.
Old Jun 19, 2011 | 01:38 PM
  #55
garys 68's Avatar
All mine lined up, no holes to drill. The mounts are right/left specific. Are you sure you have a separate right AND left frame mount?
Old Jun 19, 2011 | 08:09 PM
  #56
Aceshigh's Avatar
Hey, real quick, do you remember which pulley you swapped onto your
power steering to clear the steering box ?? I tried a 5.5" GM pulley part #
today that someone posted on LS1tech, and it wouldn't go down far enough....
I ended up mangling it taking it off so I'm out $34 for that lesson learned.
I'm debating just picking up the Ford pulley because I know it works.
I saw you swapped your bolts in a thread somewhere you posted for clearance.
But can't remember what thread on LS1tech I saw that in....
100% positive.
I drove to Tamraz auto parts in Plainfield and picked them up last week.
One has a red label and the other has a blue label, RH and LH.
One has an extra hole in it. Not sure maybe my K-member didn't have
all the holes pre-drilled out. I can snap a pic tomorrow to show you.
Old Jun 19, 2011 | 08:45 PM
  #57
sicky olds's Avatar
NôôB
nice job so far man. Love the T-56 Tranny, have it in my caprice . might i make a suggestion for it if it will work and get the short throw shifter from MGW
Short Throw Shifter link
Old Jun 19, 2011 | 09:40 PM
  #58
Aceshigh's Avatar
Thanks,
I do believe I got a short throw shifter with my T-56 purchase.
But if I'm wrong, I'll definitely look into that.
I gotta find out where guys are getting their round circular bases they
are welding into place after they put in the new trans tunnels.
Old Jun 20, 2011 | 01:47 AM
  #59
garys 68's Avatar
Dorman pulley #300-201, $14 at autozone. It needs to be pressed on past the shaft snout for the truck spacing. I used some 0.2" spacers between the pump and bracket to minimize the amount it had to be pressed on. In the end, I still had to use a female/female pipe union to press it past the shaft end. I also used allen head rounded bolts for better pulley clearance.
And btw, all 4 bolt holes in the frame mounts lined up to the holes in my crossmember. I would drill the crossmember to use 4 bolts. With the way the mounts hang off the front, I suspect all 4 are needed.
Pics of my frame mounts and pulley installation.
Old Jun 20, 2011 | 10:07 AM
  #60
oldsguybry's Avatar
NOVICE car nut
whats wrong with F85 ?
nvm , stupid question.....but its ok to put a Olds motor in a chevy pick-up ?
Old Jun 20, 2011 | 10:55 AM
  #61
oldsguybry's Avatar
NOVICE car nut
ok , I know I can be a jerk at times , but really???? even if a thread is not quite where it should be , I really dont think you need to go to that extreme....just dont click on the thread and read it then.....I also realize that this subject has already been gone through a million times and I probably dont have a leg to stand on with this , but come on....I would think that all would be welcome here.
Old Jun 20, 2011 | 03:11 PM
  #62
Aceshigh's Avatar
Okay, so I just got back from 2 parts stores.
GM Part #12607307 is the same exact pulley as Dorman 300-201
I measured width, height, and mounting depth.
5 5/16"Width x 1 7/16"height x 6/8" rear depth
I couldn't get it to work, so I'm going to seek out another option.
Go figure, there was the EXACT Ford pulley I needed in that LS1tech thread
listed on Ebay for a FRIGGIN WEEK!!!! I just saw it yesterday and it was sold.
Discontinued by Ford and no replacement part # made.
Haters live among us. That's about all I can really say.
Old Jun 21, 2011 | 03:10 AM
  #63
garys 68's Avatar
Where is the interference problem with the pulley?
I originally got the Dorman 300-123 from the LS1tech thread, but it would not fit. It's the same size but contoured differently than the 300-201.
Old Jun 21, 2011 | 07:16 AM
  #64
f-85's Avatar
Oldsmobile didnt make a modern truck or i would own one. Just taking one back.
Im a member on 67-72chevy trucks. But i didnt go to that site and start a build thread on "Olds moto into a chevy truck". I just did it. I know most guys there wouldnt like it. Wasnt the place for it. Just like how i feel this isnt the place for ls swap into a Cutlass.
This is a place for Olds guys to talk Olds. I know that most members here dont like and are not into this kind of stuff. To guys who "really" love Oldsmobiles, doing this is like pouring salt in an open wound.
Old Jun 21, 2011 | 07:18 AM
  #65
Aceshigh's Avatar
It has to be 9/16" spaced from the wall of the accessory bracket.
I could only get it pressed in to roughly 10.5/16" down and grounded
out the back of the pulley against the shaft base. Then it wouldn't turn.
I'm guessing you're not mounted as deep as the original pulley was,
but you're not having any isses with it being slightly off ?
I just ordered Dorman #300-029 because it says it's designed for the F-150's
with the 4.9L 6cylinder. I'm hoping it's the right pulley to match the discontinued
Ford E-150 pulley in the LS1tech threads.
Old Jun 21, 2011 | 08:15 AM
  #66
garys 68's Avatar
Mine is aligned correctly and didn't bottom out.
I am running 3 0.2" spacers on the bolts between the pump housing and bracket. That effectively move the pump base back so the pulley doesn't bottom out.
Old Jun 21, 2011 | 09:17 PM
  #67
Aceshigh's Avatar
You know what ??? I just now realized by your picture.....that will work.
I thought the BASE around the shaft was part of the accessory bracket.
I'll have to look at it again. God I feel like a dumba** now. LMAO
Old Jul 12, 2011 | 05:11 AM
  #68
garys 68's Avatar
Any updates?
I've got about 600 miles on mine, loving it......
Old Jul 18, 2011 | 09:11 PM
  #69
Aceshigh's Avatar
Engine is ready.
LS7 clutch / flywheel installed, F-body pan, front accessories, Ford PS Pulley.
I learned that the GTO LS2 flywheel isn't an LS2 flywheel.
It's really an LS1/6 flyweel so I wasted some loot buying one used. Oh well.
Got my Monte Carlo SS DBW pedal with my EFI connection plug.
Shipped out the harness today to www.lsx-harness.com for mods.
Got my master for the clutch, still gotta buy the new pedals from The Parts Place.
Those are NOT easy to get to under the dash......that blows.
Just gotta get a plasma cutter and prep the tunnel for my T-56 6 speed.
Then I gotta do the new fuel lines. Still debating what connectors to use.
I have no idea when I'll have it done, but I'm pretty close once I rip the
interior out and get the engine & T-56 6 speed trans mounted.
ONLY Area of concern presently is the F-body pan might be too long (fr to rear)
for me to keep my frame mounts in that same position you have them.
Any updates?
That's awesome. You're totally diggin it I'm sure.
Any regrets ?? (doubt it)
I'm really curious what your MPG will end up being. I forget what trans you put in. 4L60e ??
Glad to see you didn't have any issues with the accessory tilt from the spacers on the PS pump.
Old Jul 19, 2011 | 12:50 AM
  #70
garys 68's Avatar
I'm still running the Muncie wit 2.73 rear. Averaging about 23mpg. Only regret is no OD trans, but wasn't in the budget.
I used 3 0.2" spacers between the pump and truck bracket. It moves the pump directly back, no tilt what so ever. Only other mod was clearancing the bracket on the back that bolts to the block.
I'm not sure the spacers were required for the pulley I used to clear the pumps snout. But I realized if I pushed the pulley too far on, without the spacers, I might not be able to reach it with the removal tool.
Old Jul 19, 2011 | 02:59 AM
  #71
Aceshigh's Avatar
That's some pretty tall gears. Should be great for highway MPG.
Later down the road you could get some deeper gears and an Overdrive
to gain more holeshot power.
I'm not sure how you got around that rear bracket to avoid tilt , but if you did
you might want to let the guys on LS1tech know in that thread. I couldn't
see a way to avoid it myself.
I just put the Ford E150 pulley on mine after trashing the Dorman pulley.
I also got my Jeep steering box off a 98 Grand Cherokee.
Old Jul 19, 2011 | 05:41 AM
  #72
garys 68's Avatar
I'm not even sure if the rear mount is required, the 3 front mounts on the bracket is pretty stout. But it's just an L shaped bracket that bolts to a boss in the block. I just elongated the brackets block mount hole forward. The ford pulley was too hard to find for me. No salvage yars within an hour of me.
Agreed on the gears, a 5 speed with 3.0+ first and about a 0.75 OD would be perfect. So keeping my eyes open for a T5.
Old Jul 22, 2011 | 06:06 AM
  #73
Aceshigh's Avatar
Not sure how familiar you are with those, but the weak 80's pony cars came with them and so did V6 4th gen Camaro's.
They're inherently a weak medium duty trans with no strength upgrades I've read.
Just something to be aware of unless you've found stronger upgrades for it.
http://en.wikipedia.org/wiki/Borg-Wa...5_transmission
The next gen was the T-56 from Borg Warner which was stronger.
Being that the Olds is a large and heavy car with a 300+hp motor in it now, I'd consider that.
Old Jul 22, 2011 | 10:30 AM
  #74
garys 68's Avatar
I'm well aware of the weak T5s. 88-91 V8 camaros are probably the strongest, but I dont plan on driving it hard. And hey, they're cheap.
It's just hard to find an OD trans with around a 0.75 OD. No way a 2.73 rear will work with a 0.63 OD.
And you're going to love the jeep box swap. It no longer feels like driving a school bus.
Old Jul 22, 2011 | 01:19 PM
  #75
Aceshigh's Avatar
Ah.....I gotcha. So you're keeping your rear gear. Cool.
I hope mine works!!!!
My steering was awesome before, and smooth.
I'm going to have to throw up the steering box for sale to see if it will actually sell.
Old Jul 22, 2011 | 04:00 PM
  #76
garys 68's Avatar
Yeah, but even if I switched rear ends, I've already got the interior in and dont want to cut the tunnel. That only leaves maybe a Keisler RS500 or another Richmond. And I've heard the Keislers are about a year on back order.
BTW, keep the updates coming. Mine, with the little engine and muncie, is just too much fun not to drive every day. Yours is going to really fly.
Old Jul 26, 2011 | 06:11 PM
  #77
sicky olds's Avatar
NôôB
everyday i contemplate getting rid of my caprice lol. But then i blow away some ricer or crustang in my boat and feel better lol
Old Jul 26, 2011 | 06:25 PM
  #78
Lady72nRob71's Avatar
So I have to ask - is this economizer driving or fun driving? Sounds pretty good - just as good as my Caddy...
Old Jul 27, 2011 | 04:57 AM
  #79
garys 68's Avatar
I dont want to hijack this thread, but mine was a budget build that came with the 2.73 and muncie. That actually works out well for a DD (gas milage), and it's still A LOT of fun to drive.
If I want to tear up tires, I've still got my 68 corvette convertible with a 6.0 LS motor.
Oh yeah, and if I ever get bored, how about an over 500hp and torque bolt on and still 20+ mpg. Plenty of room in that engine compartment.
http://www.hotrod.com/techarticles/e...252/index.html
Old Aug 1, 2011 | 06:35 AM
  #80
Oldsguy's Avatar
Past Administrator
Aces,
I apologize for closing your thread so abruptly. I received some PMs indicating how popular this thread was for some members and was reminded of the effort you have put into your project and this thread. I have re-opened the thread for member participation.
Everyone please keep this thread civil.
