Brake Cable Location
Old Mar 20, 2014 | 11:07 AM
m371961's Avatar
What is the correct location for the emergency brake cable. Mine is on top of exhaust, below trans and trans crossmember. In the only drawing I found it appears to be between floor and crossmember and on top of transmission.
Seems it would rattle on top of exhaust pipes.
Old Mar 20, 2014 | 11:17 AM
m371961's Avatar
Sorry, 65 - 98
Old Mar 22, 2014 | 12:02 PM
m371961's Avatar
Laying on my back, I am guessing the cable should run across the top of the crossmember and cross under the trans.
Old Mar 22, 2014 | 12:23 PM
Have you checked your Chassis Service Manual?
Old Mar 22, 2014 | 12:30 PM
m371961's Avatar
Yea Eric, thats the only drawing I found. Mine has always been below the crossmember and trans, so I thought I would ask. Just looking at it, crossing over the top of the trans doesn't look correct, but if the CSM is correct, it must be how it is.
Old Mar 22, 2014 | 12:41 PM
To me, that illustration shows the cable passing above the crossmember, but below the transmission, just like you said.
To my eyes at least, the portion of the cable passing under the transmission is slightly greyed-out in the picture, indicating that it's on the other side of the transmission.
Old Mar 22, 2014 | 12:45 PM
Here's a super close-up of my electronic version.
Looks like it passes underneath to me.
Old Mar 22, 2014 | 04:35 PM
m371961's Avatar
Thanks MD, Now I see, (said the blind man). I am more used to prints where it would be a dotted line. Guess I need to look closer.
Old Mar 22, 2014 | 04:54 PM
You're welcome. Having a second set of eyes look something over is always helpful.
defiant1
Feb 4, 2020 08:53 PM
rootney
Jun 27, 2014 11:30 AM
dmberendsen
Apr 10, 2013 03:18 PM
macvic
Brakes/Hydraulic Systems
Aug 2, 2007 12:18 PM
bigbrother
Jun 18, 2007 12:34 PM
