Wheel Specs 66 98
Wheel Specs 66 98
Just need your opinions.
Would a wheel with the below specs fit my car?
1966 Ninety Eight LS:
Wheel Diameter 17 in.
Wheel Width (in) 8.000 in.
Backspacing (in) 4.500 in.
Offset 0.00mm
Center Bore Diameter (in) 3.270 in.
Center Bore Diameter (mm) 83.05mm
Load Rating (lbs) 2,200 lbs.
Wheel Bolt Pattern 5 x 5 in.
Offset 0.00mm
Craig,
Those specs look good to me. I have a set of Eagle 203's with Cooper 235:55X17 tires that fit my '98's with no problem. The center bores are slightly larger but anything over 3" is good.
Bruce
Bruce
