Need a pic of a glove box lock
Old Sep 27, 2010 | 08:51 AM
Kennedy6949's Avatar
Im working on my 64 98 and have a problem with the glove box lock. When I got the car it wouldn't open and I had to drill the lock out. I put a new lock cylinder in and reinstalled, now it wouldn't release from the latch.
So now I am wondering if someone installed an incorrect part. I have been unable to locate one from a reasonable source (including Fusick's) to see if it is correct. So I need a picture of a lock, especially the inside of the glove box door where the lock would attach to the latch.
Fusick's said the 98 and 88 should be the same, so wither could work.
Thanks alot.
Old Sep 27, 2010 | 04:39 PM
Thanks alot
Coldwar, Thanks a million, now maybe I can get it right.
Thanks again.
Old Sep 27, 2010 | 07:27 PM
Thanks again, coldwar. The lock mechanism had become weak over time and had a shorter range of motion, thus causing it to not want to release. A little grinding and adjusting the latch, and it is fixed. Those pictures confirmed that all the correct parts were there, and allowed me to focus on making it work.
FWIW, it appears that this lock is the same as the one from a 64 Impala.
Old Sep 28, 2010 | 06:07 PM
dlh61olds's Avatar
Looks just like my 61's.
Tab looks to be mounted wrong, maybe should be mounted so you just see the screws
inside the glove box.
Check it out.
Dave Holt
goldie442
Aug 21, 2015 11:01 AM
AZ442
Jun 11, 2015 06:26 AM
Kidcutty
Jun 13, 2010 07:12 AM
Col Wickham
May 24, 2010 11:10 PM
justagirlfromla
Mar 11, 2010 10:15 PM
