Wiring diagram needed! for "67 98
Hi there,
First time posting to the site. I have a '67 98 4dr Currently residing with a 455. It's done up in the Rat Rod fashion. 2" drop, shaved handles, solenoids to be installed, flat black (of course), ram cylinder in the trunk and going to be installed in the hood, and finally 2 glass packs (just so you don't miss me)
The previous owner had some fun with the wiring and now I'd like to put it straight. The headlight switch on the first notch only illluminates the front markers. The second notch which should turn the headlights on does absolutely nothing. Previous owner had a loose wire at the battery to connect and disconnect the headlights.
I tried to source the problem out tonight blind-folded and came up with nothing. There are instrument lights but no interior lights.
Any and all help would be greatly appreciated. A wiring diagram on pdf would be cool.
Sean
Sean
Hi welcome to the site. Sorry I don't have the diagram. I do have some advice. Your best bet is to buy an Chassis Service Manual. It will cost about 100 dollars.
http://www.faxonautoliterature.com
You can also check ebay. You may find one a little cheaper.
Hi there
I believe it is. Would you mind sending me the diagrams if possible.
Greatly appreciated.
This is currently my daily driver on top of being my project and I can't drive after dusk due to the fact I don't have lights.
Sean
Email to: sharpei6@telus.net
Sean
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
81 regency
Apr 21, 2011 06:18 PM
oldzy
Sep 10, 2009 05:23 AM
