1968 Olds 98 replacement hood hinges
Old Dec 4, 2025 | 12:25 PM
dukeomer's Avatar
The hood hinges (driver side) on my 1068 Olds 98 is cracked and bent. Mechanic had to remove the spring so I could shut the hood. Any recommendations where I could get used hinges or hinges from another GM car that could fit directly or with some modification
Old Dec 4, 2025 | 02:54 PM
Did you contact DVAP?
Old Dec 5, 2025 | 04:46 AM
dukeomer's Avatar
I did contact DVAP and they do not have hood hinges for 1968 model
Old Dec 5, 2025 | 05:46 AM
Hopefully someone can chime in with part numbers and an interchange.
Old Dec 5, 2025 | 08:03 AM
2blu442's Avatar
I've got a 1968 Olds 98 parts car. I'll check the hood hinges/springs on it to see if they are good. I know there was another member here who parted out a 1968 Olds 98 in the not too distant past. John
Old Dec 5, 2025 | 08:13 AM
dukeomer's Avatar
Thanks John. You can reach me at 832-785-8093 or email: omerc280@aol.com if you need to send any pictures
Old Dec 5, 2025 | 08:56 AM
The ONLY hinges that work are 1968 Oldsmobile, period. Any model except Toro uses the same hinges. Of course, since these also fit Cutlass/442, most big car hinges have been grabbed long ago.
Old Dec 5, 2025 | 11:32 AM
455Dave's Avatar
So true Joe… also note the early ‘68 versions only have 2 bolt holes for hood to hinge mounting… later ones have 3. I think you can interchange them but I’ve not personally tried to.
Dave
Old Dec 6, 2025 | 05:55 AM
Minibike Mark's Avatar
That was me. I still have the roller, and a couple loose parts. https://classicoldsmobile.com/forums...-frame-182839/
If John doesn't have what you need, I believe I may still have the hinges, I'll be in the shop today and try to lay eyes on them.
Old Dec 6, 2025 | 11:06 AM
2blu442's Avatar
Mark, if you have a good one that's loose and ready to ship offer it to Duke. I still have the engine in my parts car so it would be nice to keep the hood functional until I get around to pulling the engine. John
Old Dec 6, 2025 | 12:26 PM
v8al's Avatar
Registered Olds Owner
Years ago we all would have replaced the hinge and pitched the old broken one.
I'd suggest offering your old broken hinge in the parts section for shipping cost. Someone will probably need it and a competent welder might be able to repair that one up or hoodhingerepair might be able to rebuild it.
Old Dec 6, 2025 | 06:09 PM
dukeomer's Avatar
Hi Minibike Mark. If you do find the hood hinges, please give me a shout at 832-785-8093 or send pictures to omerc280@aol.com. Thanks, Duke
Old Dec 8, 2025 | 06:17 AM
Yeah, that's a big hood to have to move around with no help. I spoke to Duke yesterday, we're all set. Thanks
Boxed up and going out today! I'll text you tracking info.
bosch 68 442
May 20, 2025 05:31 PM
dukeomer
Jun 28, 2021 06:02 PM
rktolds
Sep 12, 2017 04:31 PM
allyolds68
Jun 30, 2017 02:14 AM
edzolz
Jun 2, 2017 02:48 PM
