where to find spray paint to match my body color? 64/98
Old April 3rd, 2015, 02:43 AM
1Fastolds's Avatar
I want to paint the outer lip of the wheels on my 64/98. Where is the best source to find spray paint to match my body color?
My 98 is a light blue, not sure of the exact name.
I'm keeping my fingers crossed that I can work on it this year!
Adam
olds.gbody@comcast.net
1Fastolds is offline
Old April 3rd, 2015, 06:57 AM
hookem horns's Avatar
Do a search on 1964 Olds paint codes - Wedgewood Mist would be a guess. Even if correct, you may not get a good match. If just looking for good enough, I would take a fender skirt into a big parts store and look through the racks of rattle can touch-up paints until I found one that was close.
hookem horns is offline
Old April 3rd, 2015, 07:29 AM
If you really want a match, you need to go to a good automotive paint store, which will use a computerized scanner to get a match that is very close, and then have their "expert" eyeball it and make final corrections by hand.
Anything other than that is likely to show (at least to someone with a good eye).
edit:
Here's one possibility:
https://www.paintscratch.com/cgi-bin...t-color-1a.cgi
MDchanic is offline
Old April 3rd, 2015, 07:52 AM
I have done that, it works well.
Koda is offline
Old April 3rd, 2015, 01:45 PM
ELY442's Avatar
Look into www.paintscratch.com
ELY442 is offline
Old April 3rd, 2015, 02:01 PM
NHolds's Avatar
http://www.automotivetouchup.com/tou...64/all-models/
NHolds is offline
Old April 4th, 2015, 04:57 AM
ripper27's Avatar
I toke my shirt to our auto paint store here because the car I bought was repaint a custom color and could not find out what it was , because the owner had passed away , they don't do spray cans any more just pint cans , guest have to find small paint sprayer ,
ripper27 is offline
Old April 4th, 2015, 06:13 AM
1Fastolds's Avatar
Thanks, I knew you guys would be able to help me!
Adam
Old May 18th, 2015, 05:12 PM
1Fastolds's Avatar
i got the paint from www.automotivetouchup.com and it looks great! thanks for the advice.
adam
Old May 18th, 2015, 06:29 PM
Tedd Thompson's Avatar
There are two type of tools(sprayers) that you can have mixed paint poured into that will allow you to spray what ever you want..Prevail Sprayer and Crown Tool. They should be available in most any automotive store.
If it were mine I would take the gas door in to the paint shop for a color match it's a lot easier to remove and re install...Tedd
Tedd Thompson is offline
Old August 19th, 2015, 07:47 AM
cherokeepeople's Avatar
Around here oreillys can color match the paint and put it in an aeorosol can.
cherokeepeople is offline
RAMBOW
December 7th, 2017 07:22 PM
costpenn
May 13th, 2017 03:55 PM
70ConvCutlass
Paint
October 27th, 2011 06:31 PM
rayfrausto
October 14th, 2011 11:20 AM
Want-A-Vert
February 14th, 2007 11:51 AM
Quick Reply: where to find spray paint to match my body color? 64/98
