What lurks under the window rubber
Pulled the rear window out of my 56 98 this weekend because I had a sneaking suspicion there was some rust under there. Not nearly as bad as I thought.
Yes there was a bit of a sigh of relief when I saw that it was less than I thought
I don't think it's big enough to go with a patch and there's no 'structure' worries. I may just use a little brass rod and fill the cracks. I still have to get up underneath and see what kind of rust is on the underside. If it's not too bad, then I'll fill it...if it looks like it needs a little more I'll put a small patch in.
I'll keep you posted
matchek
Sep 27, 2012 01:13 PM
defiant1
Jul 10, 2011 07:41 PM
