Things are looking up.
Old Apr 11, 2010 | 04:04 PM
66ninetyeightls's Avatar
Land Yacht Captain
OK lets see.
Car cleaned, vacuumed & waxed = Check
Safety Certificate = Check
Ministry of Transportation Appraisal = Check
Insurance Appraisal = Check
Vehicle Insured = Soon
Vehicle Registered & Plated = Soon
Its coming together. Hopefully this time next week I will be taking the boat for its maiden voyage!!!
Old Apr 13, 2010 | 02:58 AM
Yellowstatue's Avatar
You're way ahead of me...I keep walking past the '57 doing other chores...it's not washed, waxed or vacuumed, but it has insurance and a fresh license sticker...Light The Rockets!! Oh yes! The North York drive-in opens this weekend
Old Apr 13, 2010 | 05:25 AM
Land Yacht Captain
Its time to get on it then isn't it!!!! LOL
I will be going to the ministry today to finish up the registration and licensing. Hopefully going for my first real cruise this weekend.
Old Apr 16, 2010 | 06:44 AM
Land Yacht Captain
Wouldn't you know it. First weekend I can actually drive my car and the weather turns to CRAP!!!!
Old Apr 16, 2010 | 07:13 AM
cutlassgal's Avatar
Cutlass Lover
Ahhh... that's terrible! Hopefully it will get nice soon.
Old Apr 16, 2010 | 08:08 AM
Land Yacht Captain
Heres hoping!!!
Old Apr 16, 2010 | 08:43 AM
citcapp's Avatar
Isn't that part of Murphy's law?
Old Apr 16, 2010 | 04:06 PM
Land Yacht Captain
Citcapp you nailed it on the head!!!!!!!!!!
Yeah everything I said before. Forget it..... Somebody upstairs doesn't like me. The car was idling in the driveway getting ready to go for my VERY FIRST cruise and the engine decides it wants to start making a VERY unfriendly metalic snapping noise right out of the carb. So much for that idea!!! Sounds kinda like a dropped valve.
Old Apr 17, 2010 | 03:10 AM
If you dropped a valve it was better in your drive-way then out on the QEW at 120...
Old Apr 17, 2010 | 03:34 AM
Land Yacht Captain
Yeah agreed. I'm hoping its just a broken valve spring and I got lucky.
Old Apr 17, 2010 | 09:29 AM
Jaybird's Avatar
Maybe you have a bent rod or a bad lifter, or both.
While replacing my valve seals, I noticed that I had a bent rod and two of the rods had some play. So then I took off the intake and found two bad lifters. I was going to only replace the pair of lifters that were bad, gave my head a shake and decided to replace all the lifters, since the engine was open.
All this work is happening after I had painted the engine. I guess I must like doing things backwards.
Old Apr 17, 2010 | 09:43 AM
citcapp's Avatar
Jaybird,
Smart move replacing all the lifters just saves opening the engine again
66nintheightis,
Hope its something simple and cheap to fix. Good luck, damn that murphys law anyway
Old Apr 17, 2010 | 01:02 PM
Land Yacht Captain
I will be pulling the valve covers & possibly the intake off tomorrow to investigate. I shut it down as soon as I heard the noise so hopefully there is no damage
Old Apr 17, 2010 | 01:03 PM
Land Yacht Captain
Jaybird when doing your valve seals what tool did you use for a valve spring compressor?? Also where did you buy new lifters & pushrods???
Craig
Old Apr 17, 2010 | 01:22 PM
Jaybird's Avatar
Craig: My mechanic had a valve spring compressor. He showed me how to use it and he showed me how to put air to the cylinder. He also instructed me in making sure that the piston was top dead center before removing the valve spring.
I borrowed two push rods from my other complete 425. The hydraulic lifters, along with the gaskets came from Car Quest.
Old Apr 17, 2010 | 08:07 PM
Land Yacht Captain
Cool thanks very much!!
Old Apr 18, 2010 | 11:55 AM
Land Yacht Captain
So with sore back and all today I said screw it & pulled the valve covers off. I am certainly glad I did because I found a broken rocker arm on the passanger side.
Anyone have any recommendations on good replacement rocker arms??? I figure I might as well repalce the whole set. If one went odds are more a close to going as well.
Old Apr 18, 2010 | 12:06 PM
Jaybird's Avatar
Your back probably feels better, bending over your fender to get a good look at your engine. While you are at it, you might as well replace the valve seals and take out every push rod and check them. Try to determine if there is any play with the push rods, to see if there is additional damage. Since you are so close to your hydraulic lifters, you might just want to remove your intake manifold and check them. I know... It sucks to be you. Better now than when it's all back together!
Am I missing anything?
Oh yeah... Despite this setback, I hope that you and your wife had a great anniversary!!!
Old Apr 18, 2010 | 12:28 PM
Land Yacht Captain
That is the plan. I have a new intake to go on the car anyway so while I am here I might as well get it all done in one shot.
So far I have priced out stock style replacments and they are $3-4 each.
Old Apr 18, 2010 | 04:34 PM
Land Yacht Captain
Everything seems to be fine with the valve & spring. I will be pulling the intake to replace it so I will inspect the lifters at that time.
Here are some pics of what I found.
Here is the exhaust rocker from the same cylinder.
Here are some close ups. I am pretty sure it was failure due to age. You can see quite a bit of cracking around where the bolt goes through. It looks like the main break actually started at one of these cracks.
Old Apr 18, 2010 | 04:56 PM
Jaybird's Avatar
OOOOOH........ That's kinda violent. Scary stuff!
Good luck with the rest of your rebuild.
Jaybird
chris83
Jan 16, 2013 09:54 PM
kartman24
Jan 2, 2013 06:53 PM
AR15
Nov 19, 2012 09:09 AM
sicky olds
Aug 12, 2011 04:03 PM
69oldsguy
Apr 11, 2010 10:24 AM
