Speedometer bezel
Speedometer bezel
86 Olds 98 Regency Brougham..In the process of removing my speedometer. Trying to remove the speedometer bezel. There are two screws at the bottom edge that I have removed. The book says there are two screws at the top edge also, but not on mine. The bezel is loose except for the top corners. I assume it is held on by clips, but not sure, and I don't want to break it. If there are clips I don't know if they would be on the back side or the top side. Anyone familiar with this process? Thanks..
