Speed control throttle sensor
I am in need of some info on the what I am calling the spend control sensor. Mine broke and now my throttle and pedal will not work. Does anyone know what the part# or where I can get this?
What are the symptoms that make you think this pat is bad?
I have heard they can get carboned up inside and fail in interesting ways. If you can't find a new or good used one, maybe yours can be opened, fixed, and re-sealed.
I am not where I can take a picture right now and it is on the make of the firewall behind the engine. But if you look at the picture you can see the fresh metal and two bolt holes where the metal casing went all the way around the switch. with out it secure to that bracket it will not properly pull the throttle rod back.
